โMar-13-2015 08:25 AM
โMar-14-2015 04:38 PM
โMar-14-2015 10:41 AM
โMar-14-2015 09:45 AM
โMar-14-2015 08:05 AM
โMar-14-2015 08:01 AM
ewarnerusa wrote:
OK, I've opened it up and taken a photo of the fan label. I've put a few drops of oil on the fan axle beneath the sticker. I'm now googling this model number and looking for something with comparable specs. I'm navigating the Jameco Electronic link now. this fan is about 1 9/16"/40 mm on each side and 3/4"/20 mm deep.
โMar-14-2015 07:52 AM
MEXICOWANDERER wrote:
Shipping an inverter is going to be "free"?
I can find a dozen odds & ends to fill up the 7 bucks in shipping. Things like fuses, mini chargers, 12-volt mini batteries for remotes. allelectronics.com has an excellent gooseneck mini desk lamp for eleven bucks. Coin cell batteries - on and on...
Plus it's fun to recover stuff, especially if it's for backup use.
I'm sort of curious how a PURE sine wave inverter can compete with eleven dollars. Has the PSW price dropped?
โMar-14-2015 07:45 AM
โMar-13-2015 11:04 PM
โMar-13-2015 07:27 PM
This fix is taking longer discussing it than the actual changing of the fan ๐
A cheap inverter is not.going to have even a decent quality fan, nevermind a good fan.
So a surplus joint like allelectronics four dollar fan is laughably going to be quieter move more air and last 10X longer than the original. This application is for a use as needed imverter and not for something for the living room or bedroom.
โMar-13-2015 04:33 PM
โMar-13-2015 04:07 PM
โMar-13-2015 02:18 PM
ewarnerusa wrote:
Gdetrailer - the fan noise isn't happening whenever the fan runs, just when it is first turned on and typically just for the first 5 minutes or so. But this noise time has been increasing. The fan spins whether it is making the noise or not, in fact I can sort of alleviate/aggravate the noise just by tilting the inverter in my hands. After it has been running for a while, the fan grinding/humming noise stops (fan is still spinning though, normal fan noise at this point) while the same loads are being applied.
โMar-13-2015 11:59 AM
โMar-13-2015 11:52 AM
ewarnerusa wrote:Yes, it is.
y I have 4 now but only use 2. If I had just bought a nice large one in the beginning, I'd probably have saved money in the long run. Isn't that how it usually works?
