โNov-14-2020 10:13 AM
โNov-17-2020 02:24 PM
Bud
USAF Retired
Pace Arrow
โNov-17-2020 02:15 PM
โNov-16-2020 06:18 AM
jornvango wrote:Do not have to remove it. Just disconnect the output wires. Turn on the converter and measure the empty output lugs. Not rocket science.
I disconnected the 2 positive cables from the electric panel. I assume one of these cables goes to the battery, the other the converter.
One cable showed 12.6 (which is the current battery level), the other cable shows 0.00V
โNov-15-2020 01:16 PM
โNov-15-2020 04:26 AM
time2roll wrote:
OK by checking battery voltage you have verified no converter power getting to the battery.
Most likely the converter is dead. You may as well remove it for a bench test. Yes you are looking for about 13.6 volts output any time it is powered up. Don't replace it with a WFCO.
โNov-14-2020 03:32 PM
Bud
USAF Retired
Pace Arrow
โNov-14-2020 03:14 PM
jornvango wrote:
Is it possible to test whether your RV converter is working (= keeping the battery charged) by using a multi-meter?
โNov-14-2020 12:35 PM
โNov-14-2020 12:28 PM
โNov-14-2020 12:18 PM
โNov-14-2020 11:43 AM
โNov-14-2020 10:54 AM
2oldman wrote:
12.6 means you're charged. Is the solar doing that?
โNov-14-2020 10:40 AM
โNov-14-2020 10:22 AM
Bud
USAF Retired
Pace Arrow
