HWH front right
tarnold
As subject, jack is slow to none when operating. Just got this unit, 2014 PC with 325 model HWH. THERE WAS a 74โ€x24โ€ mirror glued to a wall partition until the first time I tried leveling. Frame tweaked and shattered the mirror. Iโ€™ve read the manual and watched several YouTube vids before I started and understood they are (supposed)to work in pairs. Now I know to look before fully extended, and found the right front, SOMETIMES ***** down but will not extend. The red light for that jack illuminates right away. When partially cocked(the left is fully vertical) I can tap the jack and it will move down a little. So, bound some where? Weak hydro to that cylinder? Retract works fine, but that is all springs isnโ€™t it. So where to start? Do have a call into HWH but havenโ€™t heard back yet.
13 REPLIES 13
tarnold
Again thanks all. All 4 do tilt slightly downward. These are on a 2014 unit.
dougrainer
tarnold wrote:
Op again. Just spent more time looking for that roller bearing. As for mp65-3035 that is for a 9000# jack. Donโ€™t look anything like mine. Mp65-3030 is what I seem to have 6000#, no bearing?
Correct. No bearing. But, Look at where it states Vertical stop adjustment. Does your Jack (all 4) tilt slightly down? If not, then tighten the vertical adjustment bolts to Pull the jacks down slightly. After 20 years the cables are probably slightly stretched.What I do is spray Liquid Wrench all over the pivot points to penetrate and remove any rust/corrosion that hinders the jacks from freely moving. You should be able to grab the foot and pull down vertical easily and the jack will smartly spring back up. Doug
enblethen
MP65-3030 is 6000 jack.
It does not show roller. It is located on upper end of the control rod.
Are you sure you have HWH? Can you get number off it?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
tarnold
enblethen
Drwaing MP65-3035 for roller bearing location.
Bud
USAF Retired
Pace Arrow
dougrainer
tarnold wrote:
Op. Thanks again Doug, Iโ€™ve printed off both references you pointed to. Finally quit storming so got to crawl under. Sprayed all friction points with PB blaster. Well watcha know, it works now, but donโ€™t know if the spray was just a make me feel good action. Wiggling it didnโ€™t seem to be bound up anywhere. Posts above mention a roller bearing. Hard to see/feel around but didnโ€™t see anything that looked like a bearing. There is a stout rod with circlips on both ends that the unit pivots on. Is that the bearing? Now this part is confusing to me:
LF MOD #12447. RF MOD AP7164
LR. Ap7164. RR. 12447
SPRINGS HAVE 49 COILS.
funny to me the opposite corners model numbers match. What would be the reason for that? So good to go for now, thanks for responses.
Go to the Jack pic and it will state ROLLER BEARING. The Jacks. AP and RAP preceed the actual model number. The other 2 numbers, mean that they are RAP--Replacement numbers. That means those 2 jacks have been replaced at some time. The stout rod is the actuator. One thing, The jacks when retracted, should not be perfectly horizontal or tilt UPWARD. If so, they will not swing down correctly. You will see a Cable connected on both sides of the jack with adjustment nuts. You tighten to bring the retracted jack down slightly below perfect horizontal. Kick Down when adjusted correctly will yilt slightly downward. Doug
tarnold
dougrainer
enblethen wrote:
Have you cleaned the control rod on the jack?
Make sure it is straight
Make sure the small bearing on top is free to spin.
"Make sure the small bearing on top is free to spin". VERY critical for kick down jacks. Since you have kick Down, The ACTUATOR on the jack is bad. Doug
https://www.hwhcorp.com/ml13514.pdf
enblethen
Bud
USAF Retired
Pace Arrow
tarnold
Op. Thanks Doug. These swing down 90*. Tornadoes in the forecast so might be a day before I can try your suggestions.
dougrainer
The First thing you do, is open up the manual release nut/spring loaded 2 center solenoids on the pump manifold. Those are the front Jack solenoids. You then activate the pump. IF the jacks both go DOWN(extend) then you know the Jack and HYD lines are good and not pinched. Look at the Manual I linked and it will show which solenoid is the RF. Close the solenoids you just opened. SWAP the 2 -2 wire solenoid pigtails connections on those 2 solenoids. IF the RF now extends and the left does NOT, you have a 12 volt power problem from the Main HWH control board, probably a blown RF solenoid fuse. If so, replace that solenoid fuse. BUT if a solenoid fuse is blown, odds are it has a internal short and will blow the fuse again in the future. So, if this fixes the problem and it happens again(blown fuse) replace the solenoid. IF the rf jack does NOT extend when you swap the pigtails, the solenoid is bad. Doug
dougrainer
325 JUST MEANS THE JACK CONTROL SYSTEM. HWH Jacks can be 2 types. KICK DOWN and STRAIGHT ACTING. Kick Down means they swing DOWN vertical when pressure is supplied and then extend and when retracting, they retract and once clear of the ground, will swing horizontal and fully retract. WHICH type you have will depend on the cause and help you require. Doug
This is the Service manual for a Straight 325 system.
https://www.hwhcorp.com/ml37640.pdf
MDKMDK
Don't know if this will help. I'm guessing a "2014 PC" is a Phoenix Cruiser, and not a laptop.
https://www.phoenixusarv.com/community/index.php?topic=1107.0
Mike. Comments are anecdotal or personal opinions, and worth what you paid for them.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
