I've Been A Gambler...with surplus parts...
MEXICOWANDERER
Here we have unmarked premium manual reset circuit breakers, note the part about being unmarked. Not true. The vendor either forget to mark them or purposefully omitted their amperage. It's FIFTY AMPS
I've kept an eye on BLOWN breakers especially on motorhomes, and too many of them are MATTEL grade toy 50-amp breakers.
This is a WATERPROOF meaning the insides do not turn to rust, breaker that wil improve reliability 1000%, it's price is little more than what a MATTEL breaker costs at a auto parts store. I've used this brand and it is comparable to a Littlefuse or Bussman.
https://www.circuitspecialists.com/153050.html
153050 AUTOMOTIVE CIRCUIT BREAKER TYPE III - MANUAL RESET - 58VDC HIGH AMP - SURFACE MOUNT
Item #153050
$7.55 regularly $25.17
Gimme (5)
11 REPLIES 11
pnichols
MEXICOWANDERER wrote:
Or you can do like the custom down here -- one single thirty amp at the service drop feeding a bunch of 14 gauge distribution wires.
Yep ... that kindof describes approximately what I saw when years ago I did some volunteer work in Mexico wiring new homes that we built and gave to poor families down there.
I hope no one was electrocuted during one of their rare rain storms.
2005 E450 Itasca 24V Class C
MEXICOWANDERER
accsys
Housted wrote:
So what is the amp rating of a penny?? :h ๐Ÿ™‚ :S
Housted
Not sure if that was "tongue in cheek" or not but a lot more than the fuse it replaced. That was the problem. People would use a penny in an emergency then forget to replace it with the correct fuse eventually resulting in a fire in many cases. Breakers are much safer and you can just reset them most of the time instead of replacing them.
John & Doris
Doris and Robbies Blogs
2017 Cedar Creek Cottage 40 CCK
FMCA F380583, PA, Good Sams
Housted
Let's extrapolate the argument...
Why don't houses have a long row of green screw in fuses?
I definitely remember a time when we did!! It was rather inconvenient having to find a fuse to replace a blown one, though I remember some who always kept a few pennies around for that purpose! Definitely not as safe as breakers. :B
Housted
2019 Forrest River Forrester 3051S 2014 Honda CRV toad.
1000 W Solar, converted to 50 amp
400 Amps of LiFePO4,3000 Watt Inverter, Refer converted with JC refrigeration unit, Sofa replaced with 2 swivel chairs, over cab bed converted to TV mount and storage
MEXICOWANDERER
I traced down the part number it's a fifty
The image has the lever tang drooping over the imprint
Chris_Bryant
So, once you get it, it's marked? Or are you assuming it's 50 amp? I would certainly gamble on getting a mystery breaker if it was marked. I wouldn't gamble cable protection on a hunch, though.
-- Chris Bryant
accsys
John & Doris
MEXICOWANDERER
pnichols
Soooo .... what's the matter with this K.I.S.S. 50 amp one -> just replace a melted link with spares you carry along and the whole thing is just a simple piece-of-metal-mounted-between-lugs that can be used submerged under water and still won't "short" with only 12 volts potential involved: https://www.amazon.com/Baomain-ANL-50A-Electrical-Protection-holder/dp/B01MZ68KY9?ref_=fsclp_pl_dp_7
P.S. My uncle used to carry a car battery in his small boat and dangle a naked car sealed beam headlight (remember them?) over the side taped to a broom handle. The power for the light came from the battery using naked jumper cables hanging in the water clipped to the sealed beam bulb's terminals. This made for great underwater visibility when fresh water spear fishing at night.
Simple 12 volt current path metal connectors and wiring don't care one way or the other about being submerged in (fresh) water. You can't get more rainwater waterproof than this.
MEXICOWANDERER
Or a person COULD use an alternative like this thirteen dollar piece of krap found on AMAZON.
GordonThree
Copy of the Cooper Bussman design.
I bought the official marine rated blue sea version, 30a.
They're definitely not water proof. One used for my electric tongue jack lasted four years before it turned to mush. I'll give it credit, it did withstand a lot of abuse, installed on the trailer tongue near the jack.
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
