โJul-13-2018 04:01 PM
โJul-14-2018 07:28 AM
red31 wrote:
so the model B59530 doesn't Runs on a 15 amp HCAR circuit breaker as advertised and stated in the install manual?
โJul-14-2018 06:14 AM
โJul-14-2018 06:11 AM
Dusty R wrote:
If a roof AC unite is wired with #14ga. wire do NOT move that wire to a 20 amp breaker.
โJul-14-2018 05:53 AM
โJul-14-2018 05:49 AM
โJul-14-2018 05:21 AM
โJul-14-2018 04:38 AM
pianotuna wrote:
My 13500 Dometic is on a 15 amp breaker.
โJul-13-2018 09:24 PM
โJul-13-2018 07:30 PM
TexasUltra wrote:
I was running on my generator when I tried to plug a small air compressor into the outlet in my exterior storage bay. When I did, the compressor started for a milli-second and didn't run any more. All the breakers appeared to be OK, but I re-set them any way. When I went inside I noticed the A/C was off. It had been on and running fine a few minutes earlier. I checked the GFCI plug by the sink and it would not trip or re-set. I'll change the GFCI plug tomorrow but my question is...would the A/C be on the GFCI circuit?
โJul-13-2018 06:26 PM
Old-Biscuit wrote:
That outside outlet is.......the A/C should be on it's own 15A CB
โJul-13-2018 06:14 PM
George3037 wrote:
Are you sure you didn't trip the breaker on the generator? If you have no power to the GFI the test and reset buttons may not work without power.
My A/C is on a 20A breaker but on a small generator (say a 2200W gen) its the only thing I can run. If I add more load like a compressor, microwave, large fan etc. it will trip the genny breaker.
I recently sold my small genny and now have a 3500W Predator or a 4750W Champion that will run everything.
โJul-13-2018 05:24 PM
โJul-13-2018 04:56 PM
โJul-13-2018 04:28 PM
โJul-13-2018 04:27 PM
