โDec-28-2016 09:22 AM
โDec-28-2016 01:33 PM
โDec-28-2016 01:20 PM
otrfun wrote:
Anyhow, the dealer doesn't have the capability to turn drums.
โDec-28-2016 12:50 PM
โDec-28-2016 12:42 PM
Lynnmor wrote:Appreciate the reply. Actually, the armature face on each drum appear to be in good to excellent condition---flat with no obvious scoring that I can see. It's possible the grease may have helped in that regard--lol!
Grease did not cause the abnormal wear on the drums. I believe that you are talking about where the magnets meet the armature face and, if that is the case, your new magnets will be damaged by the old drums.
What happens with new shoes or greased brake lining, the operator turns up the controller and makes the magnet work too hard just to get some braking. It's all downhill from there.
โDec-28-2016 11:58 AM
Second Chance wrote:Here's a pic of one of the Lippert 7k axles on our TH. Does Grand Design use a different type of Lippert 7k axle on their units?
No, Lippert does not use Zerk or "easy lube" fittings on these axles . . .
โDec-28-2016 11:41 AM
โDec-28-2016 11:17 AM
mbopp wrote:
There's a lot of chatter over on the Grand Design owners forum about leaking seals on Lippert axles. The problem seems to be more on the heavier axles, the 3500# ones don't have as many complaints.
โDec-28-2016 11:02 AM
โDec-28-2016 10:29 AM
โDec-28-2016 10:09 AM
โDec-28-2016 09:38 AM
