โJul-16-2013 09:07 AM
โJul-18-2013 12:28 PM
โJul-18-2013 10:23 AM
oilcan wrote:
Well, I checked my system its a magnatek 6345.
Apparently not the best by todays standards, but gets the job done and the specs
say it changes charging amps depending on the current state of the battery.
Any one have experience with this mfr/model and what insights ?
Thanks
ps - sorry for the hijack
โJul-18-2013 09:35 AM
โJul-18-2013 09:02 AM
โJul-18-2013 08:18 AM
โJul-18-2013 06:17 AM
โJul-18-2013 05:55 AM
โJul-18-2013 05:03 AM
โJul-16-2013 07:35 PM
โJul-16-2013 07:22 PM
George H wrote:X-2 and don't have a smart charger.
Been doing that for the last 7 years, our 05 is still going strong on original batteries.
โJul-16-2013 05:15 PM
โJul-16-2013 02:58 PM
โJul-16-2013 01:17 PM
oilcan wrote:You can but you'll need to check the water levels more often (maybe once a month).
Thanks for the info.
Without a wizard is it not good to kepp plugged into shore power ???
โJul-16-2013 01:10 PM
96Bounder30E wrote:oilcan wrote:
How can I tell if I have a charge wizard ?? I have a '94 Damon C class and am worried that if I leave it plugged into shore it will shorten the life of my battery.
Find your converter and then find the model number.........unless your converter has been changed out......a 1994 RV would not have a charge wizard........
If you have a Progressive Dynamics(PD) converter then you probably have a PD-9055.......this model does not support the charge wizard........
A 9160 or a 9260 is charge wizard capable.......
