โSep-10-2013 08:16 PM
โSep-13-2013 12:40 PM
โSep-12-2013 04:33 PM
DiskDoctr wrote:
Found some references to 2004 using 2002 Lincoln Navigator headlamps and the like, but can't know without the headlamp numbers.
Can you pull a headlight and look at the numbers stamped on it? Better yet, take a pic of the numbers and also of the lights when installed and post them.
Once you have a cross reference, you can likely choose from quite a number of replacements ๐
โSep-11-2013 07:05 AM
โSep-11-2013 04:42 AM
โSep-11-2013 03:10 AM
โSep-11-2013 12:43 AM
โSep-10-2013 10:51 PM
beemerphile1 wrote:
I have no idea what a "Revolution" is and you have nothing in your profile. Is this an older MH? You might have a bad ground. You might also need to run a separate power wire through a relay, again, I have no idea what you have.
โSep-10-2013 09:03 PM
โSep-10-2013 08:44 PM
โSep-10-2013 08:42 PM
โSep-10-2013 08:38 PM
Porsche or Country Coach!
โSep-10-2013 08:25 PM
