Lightweight Generator From Israel
MEXICOWANDERER
24 REPLIES 24
MEXICOWANDERER
My god. Now I have to be gender specific
He purrs even when working hard
He's is very economical.
K ?
Seattle_Steve
Jokes always lose something when they have to be explained, but Jewish boys are circumcised on the eighth day. The Abrahamic covenant that goes back 4000 years.
MEXICOWANDERER
I hate to be forced to ask, but consider me stupid. What does cutting off of something have to do with a potentially interesting generator?
Gjac
RedRollingRoadblock wrote:
bucky wrote:
Seattle Steve wrote:
The biggest problem with a generator from Israel is that after 8 days you have to cut the plug off.
I just spit coffee thru my nose.
Yep.
Not cut off. Just highly modified.
. I was drinking coffee also when I read your post. On a more serious note do you know why the 8th day is important?
RedRollingRoadb
Yep.
jodeb720
For those of us who have been looking for power generation without much noise, this is very similar to a linear Generator that NASA has developed for power on remote bodies (E.g. Moon/Mars).
They have coupled the power production to a Stirling Engine cycle. Heat is derived from decaying plutonium (which, if memory serves, about 700F degrees.
I went down this path trying to use the water heater on propane to drive the Stirling cycle, and use the water heater tank as a heat sink - as well as to heat the RV.
I eventually gave up because the BTU to watts conversion was too poor compared to a standard generator. Also the prototype was noisy - as noisy as a inverter generator.
It was an interesting exercise though and I learned a lot in terms of mechanical engineering and thermodynamics.
if you Google NASA Linear alternator or NASA Stirling power you'll find the link to the NASA site where they discuss at great lengths power production on remote bodies. None of the linear generators need oil - they use a spring and diaphragm design on linear bearings.
josh
profdant139
Here is a short video made by the manufacturer:
Product Overview
And here is their video focusing on the technology:
Short tech video
I tried to find out if these things are for sale yet but came up empty.
At 220 pounds, they could be decent built-in generators for larger RVs -- but sixteen KW is more than enough!
I wish they would make a three thousand watt mini version!!
2012 Fun Finder X-139 "Boondock Style" (axle-flipped and extra insulation)
2013 Toyota Tacoma Off-Road (semi-beefy tires and components)
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
STBRetired
Noticed how much the 2 cylinder motor was shaking the test fixture. The 4 cylinder version looked much less vibration prone, but there would need to be some kind of mechanical linkage between the 2 banks to keep them synchronized.
Interesting concept.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
time2roll
Ed_Gee wrote:
1) the comparison to solar was with regard to powering a vehicle.... not a village. You can't fit a 100kW solar system on a car!
2) where do you get "22 pounds" ?? The 16kW generator engine weighs 120kG !
And further, a 16kW very fuel efficient generator will go far to help a simple village off the grid..... even if they have to truck in a few hundred gallons of fuel every month or so.
Did you even read the link?
naturist
never mind
bucky
Puma 30RKSS
Tom_M1
Here's a couple of YouTube videos showing the concept for "free piston engine linear generator":
https://www.youtube.com/watch?v=QUbBqSu9Hdc
https://www.youtube.com/watch?v=u4b0_6byuFU
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
patperry2766
Ed_Gee wrote:
time2roll wrote:
EVs run on 400 to 800 volt batteries. Solar generating systems are being built well over 100 MW and the newest providing power at under 2 cents per kWh.
Actually I can't imagine a 22 lb generator will satisfy a remote village (as said in the link) for very long. Still need to truck in fuel at still more cost.
Otherwise for RV use let us know when Amazon has some to ship.
The article DOES say 22 lbs in the 2nd paragraph. It does say later in the article that then engine for the generator is 100 kG.
Courage is the feeling you have right before you fully understand the situation
Ed_Gee
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
