Lithium cost keep dropping!
3_tons
A FYI only, I haven’t checked into Amazon’s LiFePO4 offerings in quite some time, but just saw this today, 100a/h and 10 year warranty for $338 with $50 coupon applied…I have no experience with this particular brand (I have Aims), so I make no claims as to it’s performance, but the Lithium value quotient is becoming something to consider…
https://www.amazon.com/Enjoybot-100Ah-2000-5000-Lifetime-Off-grid/dp/B09CPWMZBZ/ref=sr_1_42?crid=30WW8IZY0IEBH&dchild=1&keywords=lithium+rv+battery+100ah&qid=1631671328&sprefix=Lithium+Rv%2Caps%2C245&sr=8-42
3 tons
58 REPLIES 58
Reisender
BFL13 wrote:
"The trailer comes with a 1200 watt inverter and is not hooked up to the microwave so I don’t see a huge load from it."
Some newer Rvs come with an inverter that is meant to run the res fridge they often come with now. Makes off-grid a challenge.
Yes I’ve seen that. But in this case it is a 3 way dometic.
I’ll wait to see how much power it uses. It’s a small trailer and the heat and hot water are hydronic, so no furnace blowers etc. It has a 163 watt solar panel on it as well with room for another similar sized unit. Until we get out there I don’t know what to expect.
Our first long trip we’ll be up your way. Starting in the Okanagan, following the gold trail up highway 3 to the coast, then a few weeks on the island starting in Victoria, tge. Up the island and the inside passage to Prince Rupert and then points unknown heading east on 16. We have a week or two of dry camping with friends as well but will probably bring a little 2 K propane generator with us. Should be fun.
Thanks for the info.
NRALIFR
BFL13 wrote:
NRALIFR wrote:
S Davis wrote:
Just finishing up my first 280ah pack, still need to torque all the connections, trim the all thread and add acorn nuts.
Eve 280ah 12volt cell
What is the form factor of the complete unit? The battery box in my camper will accommodate a single group 31 battery, and I currently have a VMAX agm. When I replace it, I’m going to be looking for a lithium group 31 with the highest AH rating. The highest group 31 I know of currently is around 155AH with BMS.
With LFP no gassing you can carry them anywhere, so the TC battery box size is not a limitation. Routing the wires might be the only factor……….
Main thing is you are not stuck with the existing battery location.
That’s true, but I’ve got a lot of work invested in improving the wires and accessories associated with the battery box so I’ll have the main battery in there regardless. That’s also where the Trimetric shunt and shutoff switch is. Just from a battery packaging standpoint, a drop-in group 31 with its own BMS and a lot of AH’s would work best for me.
About 9 months ago I was given these two U1 40AH lithium batteries that were salvaged out of hospital med-carts. I’ve cycled them in parallel about a dozen times with a 150 watt heater, and they’ll run it for about 6 hours. They’ve been sitting idle for a couple months now, and they’re currently at 13.18 volts @ 55°.
One of my winter projects is to install these inside the camper to be used solely for our 12v mattress heating pad. I’ll have them on a battery switch so they can be isolated from the main battery at night, and combined for charging. If the mattress heater flattens them, it won’t be a crisis.
2001 Lance 1121 on a 2016 F450 ‘Scuse me while I whinge.
And for all you Scooby-Doo and Yosemite Sam types………..Let’s Go Brandon!!!
BFL13
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
Reisender
BFL13 wrote:
Depends! 🙂
Relion says:
"More Usable Capacity 25-50% more capacity than lead-acid equivalent."
Many say 100% is usable with LFP, but many users here like doing 20-90s for 70% range in real life, so that compares with 50-90s using 6s at 40% range. You could do 40-90s at 50% range with your 6s too.
70 is 30 more than 40 and 30 is 75% of 40.
70 is 20 more than 50 and 20 is 40% of 50.
You also have "inverter usable" vs "furnace usable". The LFP stays above inverter alarm 11v to a lower SOC than 6s do. But you can go lower with the 6s and still run the furnace even though you can't do inverter anymore at that lower SOC.
That last explanation using the inverter and furnace makes a lot of sense and gives some clear context, at least for me.
Our new trailer that arrives in a couple or so months has two x 6 volt AGM batteries mounted under the bed. I had thought of switching it out for a battle born group 31 but I’ll see who’s it goes. The trailer comes with a 1200 watt inverter and is not hooked up to the microwave so I don’t see a huge load from it. Entertainment centre and a plug by the bed seems to be the only thing it’s hooked up to. Kinda wish it was hooked up to the microwave. That may be our first mod. We’ll see how it goes with the AGM’s but I’m not adverse to swapping it out with a battle borne.
Thanks for the explanation.
BFL13
Depends! 🙂
Relion says:
Photo in Profile
time2roll
Gjac wrote:
I thought that 100 AHs of LI was equivalent roughly to 210 amp hrs of lead acid GC batteries because you only run the GC batteries down to 50% whereas you can run the LI down to 0. My my 2 6v GC batteries last me 7 days before they are at 50% SOC, everything being equal won't 100 AH LI do the same? Would the LI equivalent last any longer running down to 0 than the 2 6v GC batteries running down to 50%?
Yes although the issue is 2x GC2 at 49% is still 12 volts. Lithium at zero cuts out completely. So a bit of wiggle room if you go beyond 50% on the GC2 that does not exist in the Lithium. I recommend going minimum 150 Ah lithium for this reason. And 200w solar should help too if you want to stick with 100. If you roll your own lithium, the 280 size is popular and priced well.
Gjac
With LFP no gassing you can carry them anywhere, so the TC battery box size is not a limitation. Routing the wires might be the only factor.
Big lesson in choosing a single 100AH battery that can run the inverter/microwave was you still need to run the furnace etc, so 100AH is just not enough for a weekend off grid.
You need two batteries, which means twice the already high cost if LFP (although reducing as noted) and a place to put them. Good thing is they can go anywhere, including inside where it is warm, so that leaves the cost.
Even better if you can roll your own for more AH at less cost---except drop ins would let you place each of two batts in different locations wired in parallel instead of all cells in one box. Depends on your RV layout what is possible and your budget.
BFL13
Photo in Profile
NRALIFR
StirCrazy
Moderator
Moderator
Gjac wrote:
jaycocreek wrote:
First I have seen a sub $300 100ah lifepo4 with coupon on Amazon.
$299 for 100 ah lifepo4 on Amazon..Wow
Maybe in several years they will be down to $200 that would be on par with 2 6v GC batteries, maybe by then I will need new replacement batteries.
man I wish we had your prices on batteries up here. a cheep 6V is 150.00 one worth using with a higher capacity is about 250 each...
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumber Queen WS100
Gjac
jaycocreek
Lance 9.6
400 watts solar mounted/200 watts portable
500ah Lifep04
3_tons
Very Nice work!! Could you provide a source for the several components??
S_Davis
Nice job on those interconnects! We so wanted to go with 280ah cells for our truck camper. We reluctantly went with 200ah cells so we could fit everything in a group 24 battery box.
Thanks, I am building three to start with two mounted in my truck where the inverter will be installed and one spare.
