โDec-06-2016 08:01 PM
โDec-10-2016 03:44 PM
Second Chance wrote:
Many modern 5th wheels are MUCH heavier on one side than the other - typically the side with the kitchen/pantry/entertainment center (and maybe even bedroom) slides. That's the case with our's - right at 1,000# heavier on the street side than the curb side (Escapees' wheel-by-wheel weights). With the stock suspension, the trailer sat 1 - 1-1/2" lower on the street side than the curb side. Some on the Grand Design forum have put heavier springs on the street side. Since we had other issues (bent axle/spindle), we opted for the MOR/ryde independent suspension. The MOR/ryde folks adjusted the spring height side-to-side to level everything out. This is also not an inexpensive solution - but what a difference in the way the rig tows!
Rob
โDec-08-2016 01:26 PM
โDec-08-2016 07:43 AM
mkirsch wrote:I agree, springs are not strong enough.
The width isn't the problem, it's the center of gravity. Did you haul a heavy toy around in the old toy hauler? A big weight situated low down in the trailer will cause it to be more stable due to the lower center of gravity.
Your new trailer probably has a lot of overhead cabinets and storage.
You don't need a sway bar, you need stiffer springs.
โDec-08-2016 07:29 AM
โDec-08-2016 05:12 AM
Old-Biscuit wrote:
I still don't understand WHAT OP is experiencing or thinking he is experiencing
โDec-08-2016 03:38 AM
Old-Biscuit wrote:
Has 5vr suspension been modified.....raised?
Go to weld shop
Have 2" square tube welded to spring hangers side to side stiffing/adding support at spring shackles
โDec-08-2016 02:03 AM
โDec-07-2016 06:29 PM
rsg63 wrote:
I did due diligence and searched this topic but found nothing.
Does anyone know of a sway bar (think Hellwig) kit for 5th wheel rv's? I'd like to add one if they exist. I've already upgraded the rims and tires, and all four shocks to KYB units. My new rig is tall and narrow and I believe a sway kit could be the answer. Can I get some chimes on this? Impossible? Insane? Slow down around curves? Are you rich? I'll settle even for that stuff. hahahaha
โDec-07-2016 06:21 PM
โDec-07-2016 06:10 PM
BFL13 wrote:
Would having a sideways tilting hitch head allow for the trailer to tilt more on turns than a regular hitch head?
โDec-07-2016 03:03 PM
โDec-07-2016 07:24 AM
โDec-07-2016 07:02 AM
โDec-07-2016 06:58 AM
