โJul-19-2021 08:26 PM
โSep-09-2021 06:29 PM
wnjj wrote:afidel wrote:
So the response of the ECU to a bad knock sensor is to max out the fuel trim. What that means is it runs the engine as lean as possible which would definitely account for the lost power. Looks like knock sensors run about $100 each, harnesses are around $45 and labor will probably be a few hundred.
Btw there's a known issue with rusting of the knock sensors so when they're replaced make sure they follow the TSB and put in the silicone dam to stop future water intrusion which should keep you from needing to do the repair again in the future.
I agree that itโs really strange to have both failing at the same time. I wonder if some other condition causes the engine to think the sensors are bad.
If you do replace them, theyโre only $36.79 each for the ACDelco sensors on rockauto.com.
When I looked into this a bit, it seems the 8.1L has the knock sensors on the outside of the engine below the exhaust manifolds so the water intrusion isnโt an issue there.
https://www.youtube.com/watch?v=z1V5Gb0VRFM
Also on Amazon:
Sensor
Connector
โSep-09-2021 06:04 PM
โSep-09-2021 08:37 AM
โSep-08-2021 10:57 PM
โSep-08-2021 02:55 PM
parker.rowe wrote:init6 wrote:
Well, I was able to get someone with a Code reader to go over and check it for me. It was creating 2 codes - The first was P0327 and the second was P0332. According to what I have looked up on them, one is Knock Sensor 2, circuit low bank 2
The other code was - Knock sensor 1, circuit low bank 1
I'm still suspecting a fuel filter which is nearly impossible to find with an adapter kit to take it from 3 ports down to just 2. I have tried to order from numerous places and they all seemed to be back ordered. I won't be back at the RV until around Oct at the earliest. If not then, December will be my next attempt.
I would check the wiring for the knock sensors. It may be pulling timing way back if the knock sensors are not reading correctly, as a failsafe. that would make it loose a bunch of power and it could backfire when you get on it, as you reported. But it is odd for them both to fail at once so I would inspect the wiring harness to the sensors.
I'm not sure why you are suspecting the fuel filter when the computer is reporting a problem reading both knock sensors.
Not that it hurts to replace the fuel filter.
โSep-07-2021 08:01 PM
โSep-07-2021 06:15 PM
wnjj wrote:
Did you ever get this sorted out?
Edit: Never mind, I just saw your other post about your RV being miles away.
โAug-18-2021 11:44 PM
โJul-31-2021 04:31 AM
wnjj wrote:init6 wrote:wnjj wrote:init6 wrote:
Just an updateโฆ. Have tried a new tank of gas. Ran all the old out first. Replaced the air filter and vacuumed out some deteriorated foam in there with a shop van. Replaced the mass airflow sensor with a new one and still the same issue.
Iโm wondering if it isnโt fuel pump or fuel filter related.
Did you also replace the MAP sensor? Also, you said the check engine light came on. What was the code? Mine was setting p0101 when pulling grades.
I donโt have a code reader but plan on getting one to see what code it is throwing. Not sure where the map sensor is.
You can stop by most auto parts or oil change places and theyโll check for free.
The map sensor sits on top of the engine under the big plastic cover. It is held in by one bolt with a washer that hangs over the sensor. Its really easy to change. I did both at the time because the MAF test uses the MAP to cross check.
Look here for a picture of it.
โJul-30-2021 09:55 AM
โJul-30-2021 05:49 AM
โJul-30-2021 12:11 AM
โJul-29-2021 11:00 PM
โJul-29-2021 08:25 PM
