LP/Electic Water Heater
bluedogwilson
Water heater works on LP but not on electric. Checked heater wiring and breaker, ok. Cannot find element, looks like a new type of heating source that I am not fimilar with. Would thank you in advance for any help. Bluedog
7 REPLIES 7
tbred
bluedogwilson wrote:
Thanks for all the help. Bluedog
So, what was the problem/solution?
bluedogwilson
dougrainer
He has a 2012 Jayco. They use Atwood. The 120 element is BEHIND the water heater and accessed from Inside the RV. Doug
tbred
Same problem here with new tt. Atwood hwh. Interested to hear advice.
Old-Biscuit
For more help you need to post Brand/Model & year of water heater. Different types/different problems/different resolutions.
Electric elements are typically on opposite side of LP burner
LP burner access from outside compartment
Electric element access from inside bottom area of WH tank under a protective cover
Did you happen to turn element ON without water in WH tank....if so it has burnt up
If Suburban the electric element will have it's own high/normal set of T-stats.
If high t-stat has tripped...electric won't get any power
Reset if tripped and try element.
Resets are in outside compartment under rubber covers
Chris_Bryant
Brand and model of water heater? New Suburban models have the element access through the exterior door, Atwood model are on the back of the tank- accessed from inside. Both use standard screw in elements.
-- Chris Bryant
time2roll
