For more help you need to post Brand/Model & year of water heater. Different types/different problems/different resolutions.
Electric elements are typically on opposite side of LP burner
LP burner access from outside compartment
Electric element access from inside bottom area of WH tank under a protective cover
Did you happen to turn element ON without water in WH tank....if so it has burnt up
If Suburban the electric element will have it's own high/normal set of T-stats.
If high t-stat has tripped...electric won't get any power
Reset if tripped and try element.
Resets are in outside compartment under rubber covers
