โSep-22-2019 07:02 PM
โSep-23-2019 10:57 AM
Just a thought on your existing inverter, the symptoms reek of a "cold solder joint". I believe there are 2 printed circuit boards on that unit. Might be worthwhile to go through and resolder all the joints just to see what happens.
โSep-23-2019 10:33 AM
โSep-23-2019 10:28 AM
โSep-23-2019 08:44 AM
โSep-23-2019 08:12 AM
bkf wrote:While plugged into utility power 30 to 45 amps is plenty. If you expect fast battery charging from a generator 60 to 90 amps would be better.
@time2roll, thanks. That's an interesting option. You have any thoughts about the size of charger? I've got 4x6v (wired series+parallel so 12v and ~460ah, I believe), but the batteries (for now, while we're not moving much) are just used for the lights, fridge, tankless water heater... not much. It'd be a lot cheaper to get a charger, that's for sure.
โSep-23-2019 03:34 AM
โSep-23-2019 12:22 AM
โSep-22-2019 11:20 PM
โSep-22-2019 10:05 PM
โSep-22-2019 08:58 PM
โSep-22-2019 08:56 PM
โSep-22-2019 08:32 PM
