โJun-07-2016 08:11 AM
โJun-07-2016 08:45 AM
โJun-07-2016 08:32 AM
djousma wrote:
Don't try to plug into a 220v dryer or welder outlet. they look the same but you will fry your electrical appliances in your trailer.
โJun-07-2016 08:28 AM
Mote wrote:
Most camper run on 110 volt. They do however need a 30amp power source. Your adapter is allowing you to use it on a 15 or 20amp power source. Your extension cord is getting hot since it is not large enough wire to pull that kind of power needed for the A/C.
If the houses you are going to don't have a RV specific 30amp 110 volt plug for you to attach to then will need to run a generator.
โJun-07-2016 08:27 AM
โJun-07-2016 08:25 AM
