Metal roof maintenance
wildwest450
I washed the roof on my new to me camper this morning, it looks really good. I was a little concerned with this caulk at the front, does it look ok? It seems to be pulling away a little at the very ends, should I just go over that or plaster stuff over the whole thing?
I have proflex rv sealant, which is what I used on my fantastic fan installation. The guy at the rv place said it was mainly for vertical caulking because it was hard to work with on flat surfaces(I didn't think so). What does the collective recommend??
5 REPLIES 5
JIMNLIN
Hmmm, if you fill it up and later have to remove all of it to get to the lap joint for a repair you will kick yourself.
If I was going to keep the trailer I would remove all the sealant or all That would come off with a steel putty knife and do it right.
wildwest450
JIMNLIN wrote:
Looks like someone ran a second layer of sealant over the OEM sealant which isn't the best idea as now it makes a dam for water to sit behind.
Same with adding Eternabond.
Make sure both those layers of sealant are removed as Eternabond is thick to begin with.
If it was my roof I would remove the old sealant and use Dicor self leveling sealant for a OEM look.
If you go with Eternabond I would add a self leveling sealant around the edges as the pros do for that OEM look. Do a youtube on the subject. Lots of vids out here for the do it yourself types.
Would you recommend filling that channel up?
JIMNLIN
wildwest450
I'll check it out, thanks.
gbopp
I would clear the area well, remove the loose cauld and fill in any gaps with Dicor self leveling caulk.
Then, I would cover the whole seam with Eternabond.
Eternabond is a one time repair.
I read that some of the new units coming out of the factory are using it on seams.
Eternabond Posts
Type a product name
