โAug-08-2014 07:09 AM
โAug-11-2014 01:55 PM
mchero wrote:
. . . would also like to add one of those Veerizon Hotspot/wireless router. I see models with a detachable antenna so I could mound a cell antenna on the top front cap & connect to the hotspot.Then I would have a wireless access point thru Verizon's 4G.
mchero wrote:
Will also be able to connect items like a Morningstart MPPT controller to the mix.
mchero wrote:
Was thinking Satellite internet BUT I see a lot of bloggers ae switching over since Verizon's 4G is so fast.
โAug-11-2014 12:12 PM
โAug-08-2014 03:10 PM
โAug-08-2014 12:52 PM
โAug-08-2014 12:27 PM
wcjeep wrote:Actual measurements! Sweet! Great info and thanks much! To the OP, do you still have unlimited data on Verizon?
Can't answer the Morning Star question. I would not worry about detachable antenna on the Myfi. I'd consider a signal booster. Verizon devices are capped at .25 watt output. The Wilson Sleek is about 1.8 watts. The next step is more expensive. The Wilson Mobile Pro 4G is also more powerful and universal. The Mobile Pro 4G has an advertised 5ft range. This is being generous. I would place the Myfi directly on or next to the internal antenna.
The Mobile Pro 4G is good for 5 device. I've only tested with 2 at the same time. The Sleek is good for about 18db gain. The Mobile Pro is advertised at 50db gain. I average 35db gain.
โAug-08-2014 08:42 AM
โAug-08-2014 08:37 AM
โAug-08-2014 07:41 AM
โAug-08-2014 07:21 AM
โAug-08-2014 07:17 AM
โAug-08-2014 07:15 AM
