โJun-25-2017 10:47 AM
โJun-26-2017 08:45 AM
โJun-26-2017 08:15 AM
Roller4Tan wrote:
I think if you get a mount that is easily removable or can take the tv off of it while traveling, it would reduce the stress on the screws and make for a lasting mod.
โJun-26-2017 06:17 AM
โJun-25-2017 04:07 PM
โJun-25-2017 01:43 PM
Old-Biscuit wrote:
Bet the end cap is NOT aluminum studs or wood blocks are installed for ladder mounts
โJun-25-2017 01:18 PM
As for frames etc......not much load bearing so screws will hold but can strip out very easily.
Weight capacity/Load bearing requires nuts/bolts or welding when aluminum is used
โJun-25-2017 12:14 PM
โJun-25-2017 11:51 AM
โJun-25-2017 11:43 AM
Old-Biscuit wrote:
1st off......
Screws do NOT hold in aluminum studs/rafters
That is why they are bolted or welded........
โJun-25-2017 11:22 AM
โJun-25-2017 11:19 AM
โJun-25-2017 10:57 AM
