โNov-03-2016 08:39 AM
โNov-17-2016 08:20 PM
โNov-17-2016 05:39 PM
โNov-16-2016 07:58 PM
westend wrote:
How many amps continuous do you need?
โNov-16-2016 07:32 PM
โNov-16-2016 06:43 PM
CA Traveler wrote:mchero wrote:Since you are both Senior Members both of you know the answer.
pnichols
This will be the THIRD time I posted the model of my Isolator solenoid! Don't you folks read the entire posts?
Right? ๐
It's just the way it is. :B
โNov-16-2016 06:04 PM
scrubjaysnest wrote:
Our experience with the Trombetta is they get very hot. Since I rewired the B.I.R.D correctly the solar now feeds the cranking battery and yes during the early AM and late PM the Trombetta will chatter. It is also on my replacement list before we leave for AZ next month.
Haven't made the decision to add a switch to drop out the Trombetta or not; most likely will. Cranking battery only needs topping off about once a week for us if we sit still that long. The only loads I've found on the cranking battery thus far are the night shade motor, Trombetta and B.I.R.D, and DW's tablet over night.
Will switch the tablet over to the house batteries once I upgrade the USB charging bank to something higher then a 1/2 amp.
โNov-16-2016 05:57 PM
pnichols
โNov-16-2016 05:46 PM
โNov-15-2016 07:01 PM
mchero wrote:
I'm already down here in AZ scrubjaysnest. I'm in Quartzsite here in LaPosa West in the LTVA
'll tell ya right now, Trombetta is ****! I have replaced three and I just found out the current Trombetta is now toast! The frekin contacts DONT LAST.
Im looking for something other than a Trombetta!
That solenoid should NOT chatter!
โNov-15-2016 04:54 PM
โNov-15-2016 04:48 PM
landyacht318 wrote:
A Continuous duty solenoid can be either latching or non latching.
Do not feed a latching solenoid a constant 12v.
I do not know if your solenoid is latching or not.
When Mex's posts contain lots of spelling errors he is typing with fat thumbs on a smartphone, and is limited in search ability.
If a non latching solenoid is getting warm to hot passing minimal solar current to a nearly fully charged chassis battery, something is wrong with it.
I use Blueseas 6007m manual switches to send or take juice where I want.
Right now all 3 switches,(solar, chassis and loads) are all turned to battery 2, as there is no longer any battery 1.
โNov-15-2016 04:44 PM
โNov-15-2016 03:37 PM
โNov-14-2016 07:40 AM
โNov-14-2016 07:35 AM
