Need help wiring Honeywell thermostat
Chevyman2006
I removed the old Dometic thermostat last night to install a Honeywell thermo and can't get it to work. Of course, I didn't pay attention to where the 3 wires went on the Dometic and can't get that one to work either.
I've attached the pictures of the old and new thermostat as well as the wires coming out of the wall.
PLEASE HELP...it's 86 degrees in GA!
Wires
New Thermostat
Back of new
Old Dometic
Old thermo terminals
2006 Chevrolet 2500HD 4wd CC/SB Duramax/ Allison
2009 Keystone Copper Canyon 298fwbhs
Wife and two BEAUTIFUL girls!!
Nights camped in 2010: 64
Nights camped in 2011: 58
Nights camped in 2012: 75
9 REPLIES 9
Dutch_12078
Chevyman2006 wrote:
I had a Hunter in it until camping World changed it.
The Dometic Single Zone LCD Thermostat comes with a new control box for the A/C with a different wiring setup.
Dometic SZLCD Installation Manual
Dutch
2001 GBM Landau 34' Class A
Chevyman2006
time2roll wrote:
Do you have a voltmeter? Check that you have 12v red to black.
If you have voltage you can open up the interior ceiling access to verify the Orange wire is connected or some other color.
I do have one, but I'm an idiot on working one.
sayoung
If that Honeywell is a standard residential thermostat I don't think it will work with only 12voolts as we use 24 volts on residential equipment. It might work with the batteries installed.
time2roll
Chevyman2006
lj2654 wrote:
on your old thermostat same as mine:
black wire goes to 12v-
orange to comm
red to 12v+
I am not sure how to wire the Honeywell thermostat
This isn't working
Is there something else I can check? Yesterday I could get the screen to work on the old Dometic...but now nothing.
Chevyman2006
time2roll
Honeywell will not work with the digital control board up in the ceiling.
Above colors sound correct.
It looks like the prior owner upgraded your thermostat. The twisted/curled ends are probably not used anymore. The three wires with straight ends that are trimmed are probably what you removed from your single zone.
There is an updated single zone now available. Called Comfort Touch.
Still not programmable.
http://www.adventurerv.net/dometic-single-zone-lcd-control-thermostat-3313192000-p-29797.html
lj2654
orange to comm
red to 12v+
2001 Beaver Contessa Naples 40
2012 Cadillac Srx
retired AirForce 1979-1992
2oldman
Other than following the wire color scheme, or looking at manuals, I wouldn't know what to do.
Dang.. how many times do we tell you guys to take pictures before doing this stuff!! ๐Ÿ™‚
