Jun-13-2022 10:45 PM
Jun-21-2022 05:01 PM
3 tons wrote:I wish PD would read some of this....
Well after all this, what’s left to know about LFP’s!! - lol 🙂
3 tons
Jun-21-2022 04:58 PM
Jun-21-2022 09:18 AM
Jun-21-2022 07:26 AM
Microlite Mike wrote:
My comment about air shipment was merely in response to your opening sentence. They ship them with the 30% SOC due to regulations rather than ideal storage SOC. Prior to the regulation Lithium batteries often left the factory at 100% SOC (or close to it).
Jun-20-2022 07:51 AM
otrfun wrote:Microlite Mike wrote:Some of the discussion here is a somewhat, in-the-weeds debate about ways to maximize cycle life. Some of the SOC and charge voltage monitoring required to implement some of the charge profiles (for only a nominal increase in cycle life) is probably overkill for the average user. Only someone who places a higher priority on cycle life vs. usability would find it worth their time.otrfun wrote:Yes, 30%-50% may be an ideal SOC for long term storage but since April 1 2016 international regulations regarding air shipments of Lithium batteries restricts the SOC to 30% or less.
Lastly, lifepo4 cell/battery manufacturers ship their units with a 30-50% SOC for a reason. It's the ideal SOC for a lifepo4---for the short and long-term.
FWIW, my solution to the storage issue is to just go camping regularly and since I primarily boondock, batteries are constantly being cycled. I just follow Battleborn's recommendation when I return from a trip. "Charge to 100%, disconnect, and just charge again after 6 months of inactivity" (which has yet to occur).
With 200 ah of storage and a daily average consumption ~50 ah, I will complete a full charge cycle every 4 days. If I were to "Full Time Boondock that would amount to 91.25 full cycles per year. Battleborn advertises 3,000 to 5,000 cycles from their batteries. This amounts to 32 to 55 YEARS of battery life based on cycles alone.
Most LiFePo4 batteries in RV's will most likely outlive their owners and possibly those who inherit the RV and batteries.
Reality Check, LiFePo4 batteries are also subject to internal chemical degradation like Lead/Acid chemistry batteries. Even with the most careful charging practices they will most likely age out somewhere after 10-12 years which is why the best warranties max out in that range.
I only mentioned the 30-50 cycle as an extreme example of how to maximize lifepo4 cycle life--just to make a point. Rather doubt it's worth anybody's time to actually implement it because it would reduce the ah capacity of the battery to a ridiculously low level.
As for your comment about air shipment of lifepo4's at 30% or less SOC, I'm not sure how this fits into the current discussion. Maybe you can clarify.
Bottom line, as I mentioned in an earlier post (and as you also somewhat alluded to), the average user can get by without having to resort to any special charge profile and still obtain many, many years of use from their lifepo4.
Jun-19-2022 10:58 AM
Jun-19-2022 10:05 AM
Jun-19-2022 07:21 AM
Jun-18-2022 07:22 PM
Jun-18-2022 05:42 PM
otrfun wrote:
Lastly, lifepo4 cell/battery manufacturers ship their units with a 30-50% SOC for a reason. It's the ideal SOC for a lifepo4---for the short and long-term. I think it's just a matter of time before manufacturers eventually transition to 3-stage units to address this unique lifepo4 storage/float requirement. Until then, those set-it & forget-it folks (who may be striving for maximum lifepo4 cycle life) will just have to remember to turn-off their 1 and 2-stage lifepo4 converter/chargers when they're not camping.
Jun-17-2022 11:34 AM
Jun-17-2022 08:41 AM
BFL13 wrote:Excellent questions!
Note that I am not advocating for leaving the LFP connected while on shore power with an active converter.
I am commenting on how the converter makers see the problem, where they assume the converter will be on during shore power time ( nearly all the time for most RVers AFAIK), and they have to be sure a connected LFP won't be ruined during that time. (They do not imagine the RVer disconnecting the LFP)
So their various attempts to make the converter "compatible".
Guys on Tech Issues are not like most RVers? which means they are more likely to be willing to do a few things instead of being totally automatic and hands free?
Just saying that so far IMO it seems the converter makers have not solved their problem of making their converters totally "compatible" with LFP (something of a moving goal post itself for what is needed?)
I did say their converters are not totally compatible with FLA and AGM either, but the penalty in dollars for the RVer who treats them as such is low compared with the penalty cost of doing that with LFPs.
The OP is trying to get as close as he can to hands free by maybe swapping out his converter, but it seems like he is as good as it gets now with his OEM converter, unless he wants to do more manually himself.
Jun-16-2022 05:08 PM
Jun-16-2022 04:43 PM
