New Dometic Fridge
big_murph_279
Got a new camper this weekend and it traded in our 07 unit. The old camper had a Dometic fridge/freezer. I would say it was the standard size. Bottom fridge, upper freezer. The new camper has a newer version of what our old one did. Same size but nicer looking with LED lights and stuff. The new one has a fan that runs inside the vent area. I know a lot of people have put these in but I didn't know that they were on new units. I never heard it on my old unit. Did it have one or was it broke? Will this fan be a problem when dry camping? I don't see a way to cut it off. Also, neither the old rv or the new one has the fridge located in a slide out.
Thanks
3 REPLIES 3
nineoaks2004
The fan is probably turned off /on by a button thermostat and should shut off it the temp gets to a pre set (by thermostat) and as soon as the unit heats upit will start the fan.
By the time you learn the rules of life
You're to old to play the game
downtheroad
Is the frig in your new unit located in a slide? If so it needs the extra exhaust fan to cool properly.
Maybe the frig in your old trailer wasn't in a slide...thus it didn't necessarily have the fan that you are now hearing...???
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
Old-Biscuit
Model would help?
Fan improves draft---better draft/better cooling
Fan probably draws less than .5A when running and is controlled by a thermostat on condenser fin
