โMay-17-2013 04:23 PM
โMay-18-2013 03:56 AM
โMay-17-2013 08:43 PM
tsweez wrote:
Okay, so I found the charger under my fridge. It's a Magnetek 6300A Model 6345 which I assume is far from what I need.
โMay-17-2013 08:21 PM
tsweez wrote:4x GC2 I recommend a 75 or 90 amp IOTA with built in IQ controller.
โMay-17-2013 07:41 PM
โMay-17-2013 07:39 PM
โMay-17-2013 05:48 PM
โMay-17-2013 05:19 PM
mena661 wrote:
Like donn mentioned, change your converter out for a 3 stage unit. Two, 1500w inverter is too much for just TV and sat and not enough for most microwaves (unless its a small one then maybe). Also, go for 4 6V batteries if your going to be boondocking a lot.
EDIT: just saw your requirements. You are correct, 1500W for all that at the same time.
โMay-17-2013 05:09 PM
HiTech wrote:
Having a house battery in the engine compartment does have the advantage of short lines to the alternator for fast charging.
Jim
โMay-17-2013 05:04 PM
Trackrig wrote:
The below sites will give you enough reading for a week. There's one more that Mello Mike put together of a lot of solar installs, but I can't locate it at the moment.
The 12 Volt Side of Life - Part 1
The 12 Volt Side of Life - Part 2
Jack Mayer's Solar Site
Senior Moment's 12V and Solar site
Handy Bob's 12 V Battery Chraging & Solar
Bill
โMay-17-2013 05:00 PM
โMay-17-2013 04:56 PM
โMay-17-2013 04:52 PM
โMay-17-2013 04:36 PM
