New toilet
jgrimes
Been considering replacing the Aqua-Magic Style II toilet in my 2014 Solitude due to repeat problems. Anyone replaced their's with a Dometic 310 Series? Suggestions?
17 REPLIES 17
Ron3rd
Ed_Gee wrote:
rhagfo wrote:
Dometic 320 here love it!
DITTO!
X2 Get the tall version as noted above
Equilizer Hitch
Honda EU2000
Gjac
What are the repeat problems that you are having?
352
jgrimes wrote:
352 - not totally sure on how to do it. Need a demonstration. My problem is with repeated issues with flush arm/rubber washer etc. Tired of paying to fix it.
I have had a video out for years. You must have missed it. Go to squeeze the poo in the search column
The manatees of Halls river Homosassa Springs Fl
1985 Chevy Silverado c10. 454 stroker / 495 CI = 675 HP. 650lb of torque. Turb0 400 tranny. 3000 stall converter. Aluminum heads. 3 inch exhaust flowmasters. 2 inch headers. Heat and air. Tubed.
Cummins12V98
Lynnmor wrote:
Cummins12V98 wrote:
Lynnmor wrote:
My ball valve split right in the center, I learned the hard way.
DANG, did they replace it under warranty?
They have a two year warranty and it was a bit over that time, so I didn't pursue it.
I was camped at Shipshewana and the neighboring camper was having his 320 replaced for the second time, so I asked the factory authorized repairman about parts and he said that he might be able to help in a few days. I didn't have the time so I just replaced the entire toilet. The porcelain and plastic base are bonded together and disturbing that bond can result in future problems, so parts aren't offered.
Thanks! I have been so happy with mine that i should buy another for sure.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
jgrimes
352
If you had the pyramid problem proceed as follows. Reach your hand down the hole as far as possible. When you feel anything chunky squeeze it between your fingers until it not chunky. Put 5 gallons of water down the hole and put you arm back in and swirl it around. Give it a few minutes and letr rip.
Lynnmor
Cummins12V98
Lynnmor
Cummins12V98
Lynnmor wrote:
theoldwizard1 wrote:
Lynnmor wrote:
Consider the 310/320 as a throw away item, the ball valve cannot be replaced.
It appears that the seal can easily be replaced.
That is why I said "ball valve" not seal.
3.5 years and the "BALL" is just fine. Occasionally remove the seal and give it a good cleaning. dry it off and coat the bottom side of the seal with Vaseline. Now with the ball closed push the seal into place, you may need to open the valve to finish positioning the seal. Clean the ball good with DAWN and some Hot water also before replacing the seal.
Most issues are people knocking one of the ball side supports off when cleaning the toilet.
WaLa it's good to "GO". ๐Ÿ˜‰
Cummins12V98
YUP, love ours. 3.5 years of full time use, QUALITY product!
AT-HOME COMFORT
With an enameled elongated seat, residential height, and a lustrous high-fired vitreous china bowl, the Dometic 320 RV toilet makes you feel right at home. The ergonomic height offers easy accessibility for people of all ages, and the fully enclosed rim delivers a full-circumference flush that cleans the entire bowl every flush.
Lynnmor
Ed_Gee
DITTO!
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
theoldwizard1
