Newbie with electrical problem.
dumplin57
Hi folks, I'm new to the forums. I have a 2006 Cedar Creek 5th wheel that I'm having an electrical problem with.
Problem: the five 120V a/c plugs in the living room/kitchen just quit working.
Whats been done:
1, had the RV park handyman come check it out.
Replaced GFCI in bathroom and one suspecious plug.
2, replaced 20A breakers.
3, checked all conections in breaker box.
4, removed each 120V plug, removed wires and checked for power.
5, checked all exterior, storage bay and fridge plugs.
I'M AT A LOSS. Has anyone else had this happen and can shed some light?
18 REPLIES 18
enblethen
OP:
Please answer the previous questions.
What type of service 320 or 50 amp?
Do you have a large inverter?
Was there power leaving the circuit breakers?
Calling manufacturer will do no good without some answers!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Pogoil
Inverter.
Pogoil.
aruba5er
Which is the FIRST outlet then the SECOND and so on? It should be required to provide a secematic of how the wiring was done.or photos before the walls go on. Most wiring I am familar with on an rv is Vampire connections where the wire is pokked into the back of an outlet and a cover snapped over it. If that outlet fails the others down the line still work. GFCI outlets still have screws so maybe the load has loosened up a wire and has caused the trouble. I would check at the gfci first. Pull it out and test, just don't look at it. I've changed too many that have reset and still nothing comes out.
Matt_Colie
Dumpin,
Read What Donn Wrote....
All these new RV have the "self enclosed- fast wire" receptacles. The only reason that these things are not a complete POS is that parts are missing.
So, if the factory cannot get you a wiring diagram (no bet there), just get a thing that plugs in - not a test light. I mean a thing like a hairdryer that will care if it is not getting juice. Work from the receptacle nearest to the panel and keep moving away. When it stops, go back one. Open the breaker (the tester better stop). Take that receptacle out and open it up. There are opening and disconnecting instructions on the device in little tiny eantsy bitty letters (I have to get a magnifier to read). Open it up and check the wires first by pulling - they should not pull out. Then release and inspect each conductor. It that one checks, go to the first dead receptacle and repeat this whole show.
It isn't rocket surgery, if you are literate (you can run a computer) there is no reason you can't do this and if you do it successfully, just think of the money you can now spend better ways.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
donn0128
dumplin57 wrote:
Well as I said before, I've done all of that. Guess I'll call the manufacturer. Thanks.
Yea, I know you said that, but.... Do you have 120VAC at both sides of the breaker? Do you have 120VAC at the first outlet? This aint rocket science, you have no 120VAC some where. If you have a series of outlets dead, then the last one on the chain that has power is your problem. The cheap junk outlets that are used have crappy push on connectors. Guaranteed you will find no power at one of those connectors.
enblethen
OP has not responded to what amperage of service, whether using an adapter, or whether it is equipped with a large inverter.
Hard to give good advise with all the pertinent information.
Bud
USAF Retired
Pace Arrow
Broccoli1
30 amp or 50amp rig?
If 50 amp i would check that your getting power to half the center. maybe the main breaker is bad
06 F250 V10 SB 4x4 Gulp Gulp
WW FSC2800
Rhino 660- 1980 Cobalt 18DV
CRF 50 & CRF 70
"Shoot, I'm the world's best backwards driver!"
enblethen
Bud
USAF Retired
Pace Arrow
dumplin57
MEXICOWANDERER
Is it possible the manufacturer can come up with an even stupider design? I doubt it. I read these threads with wonder. It's like the simpler more intelligent days of RV'ing have gone round the bend and off the tracks. What is the purpose of "Sit On Your Butt While Everything Is Done Automatically" when nothing works, and a person spends all day and half the night running around like a chicken with their head cut off? Are customers insisting on this lunacy?
wa8yxm
And if it is a KITCHEN breaker then for sure it's on a GFCI. So is the patio, and Bathrooms (Where the GFCI is often located) HOWEVER just because you found ONE GFCI does not mean they did not hide one.. I know of folks who have found 'em in some very strange places.. Myself included but that was on a Sticks & Bricks.
donn0128
I'll tell you exactly what the problem is. All of your outlets except those in the kitchen are daisy chained from the breaker panel to the first one, then the second one etc. Start at the breaker and be sure the connection is clean and tight. Move to the second outlet and do the same. Keep moving around all of the receptacles until you have checked all of them. Next, connect the power back to the trailer and start taking voltage readings. This is not rocket science, but it will take some time and patience to find the problem. When you are checking wiring be sure that the insulation is not being clamped on. Have seen that a lot over the years and it always causes problems sooner or later.
1492
Moderator
Moderator
Moved from Forum Technical Support
Mandalay_Parr
Your inverter may have a breaker on it.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
