No 12 Volt System
Crazy_Ray
When I unplug from shore power I have no 12 volt system working. Anybody have any ideas. Thanks for your help.
RET ARMY 1980,"Tiny" furkid, Class A, 2007 Bounder 35E, Ford V10 w/Steer Safe, 4 6V CROWN,GC235,525W Solar Kyocera, TriStar 45 Controller,Tri-Metric 2020,Yamaha 2400, TOW CRV. Ready Brake. "Living Our Dream" NASCAR #11-18-19-20- LOVE CO,NM,AZ
9 REPLIES 9
Crazy_Ray
All of you that are helping me, I will check the things you have said Monday morning and let you know. thanks Ray
time2roll
Crazy Ray wrote:
battery power is reaching 12 panel (BCC box
So the stack of branch fuses all have 12v power when just on battery?
This is not adding up.
Must be a problem in the BCC box. Does it have a make or model number?
mena661
On my rig, there is a resettable DC breaker on the ground wire (negative) within a couple of inches of the frame (front bumper).
BFL13
As above.
Plus where is the BCC box? Are you getting that same battery 12.9v there? I don't have a Class A, so I can't tell if the 12.9 is well inside past those things like the battery disconnect switch etc I first mentioned.
On that switch, you have the switch you use inside the rig, but it just switches another switch (solenoid) somewhere (by the engine?) that sometimes sticks and causes the problem.
Anyway somebody who knows Class As would be more use than I am here.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
handye9
Crazy Ray wrote:
What do you mean fuse or DC circuit breaker within 18" on battery + side? Thank you. Ray
DC auto reset breaker
In-line fuse holder
Disconnect shore power and/or tow vehicle. Wait a few minutes and reconnect. If problem is still there, look for an in-line fuse or circuit breaker on positive side of the battery. They're not always within 18 inches.
Some of the breakers are auto reset (that was purpose of the disconnect and reconnect), some have a push button. When they won't reset, they need replacement. They are available at most auto parts stores.
Start at house battery/s and follow the positive cable, back towards the converter.
18 Nissan Titan XD
12 Flagstaff 831FKBSS
Wife and I
Retired Navy Master Chief (retired since 1995)
Crazy_Ray
BFL13. My converter is putting out 13.39 volts, battery power is reaching 12 panel (BCC box), Battery disconnect switch is working. What do you mean fuse or DC circuit breaker within 18" on battery + side? Could not find any fuse. Battery reads 12.9 at battery/TriMetric/volt meter. Batteries wires clean. What else could be wrong? Thank you. Ray
time2roll
Battery is dead or has an open connection to the RV.
Voltmeter will tell the tale if you start poking around.
rjf7g
I just had to replace an in-line 50A fuse that shorted out because of moisture...it was within 18" of the battery.
1999 American Cruiser Class B
2006 Palomino Puma 27FQ Bunkhouse
2007 Gulfstream Innsbruck 36FRS Park Trailer
BFL13
Your converter works ok!
Battery power not reaching the 12v panel. Why not?
-battery disconnect switch
-battery fuse or DC circuit breaker within 18" of battery on pos wire
-dead battery
-battery wires corroded no contact
Photo in Profile
