โNov-09-2015 08:53 PM
โNov-13-2015 04:39 PM
somewhere in the texas 'lost pines'
โNov-10-2015 12:41 PM
โNov-10-2015 09:19 AM
โNov-10-2015 08:48 AM
โNov-10-2015 06:10 AM
GordonThree wrote:Sports, Limbaugh and religion.
AM radio is still being broadcast? Amazing
โNov-10-2015 06:07 AM
tempforce wrote:
am radio needs a ground plane. like on a car the antenna is grounded to the metal body. the rubber roof doesn't provide a ground plane. you can remove the antenna from the roof. on some units it must be unscrewed from the inside.. once you get the antenna detached place a 1-2 foot diameter piece of metal, tin, copper, steel, ect. it can be 1/16-1/8" think more or less, whatever you have handy... drill a hole in the center the same size as the hole in your roof. then paint the plate your favorite color, both sides to prevent corrosion.. place it over the hole the antenna was located. then re-install your antenna. you can put some silicon, contact cement or some other adhesive between the rubber roof and the metal if you want. you can put a bead of sealer around the edge as well. just make sure you have a good seal between the antenna and the roof, to prevent a leak...
radios in r.v.'s are notorious for poor reception.
โNov-10-2015 03:39 AM
โNov-10-2015 12:37 AM
โNov-10-2015 12:33 AM
โNov-09-2015 11:56 PM
