โSep-10-2018 04:39 PM
โSep-12-2018 05:48 PM
D.E.Bishop wrote:
First off, you have been a member long enough to know you are not asking questions specific to your problem. Why was the cable disconnected, what antenna do you have, have you checked out the cable by taking a voltage reading at the antenna connection, do you have the manual for the system? If you replaced or an old cable it is not uncommon for a whisker from the shielding to short out the cable. Is the system wired correctly, did you look at the manual to make sure?
Get the manual and follow the installation and trouble shooting instruction, then if you have a problem come back here and someone will have an answer for you.
โSep-12-2018 07:21 AM
โSep-12-2018 04:27 AM
โSep-11-2018 06:44 AM
โSep-11-2018 06:38 AM
โSep-11-2018 06:18 AM
โSep-10-2018 11:35 PM
โSep-10-2018 08:49 PM
โSep-10-2018 05:41 PM
