Noisy Furnace
Bluebeard
My 2001 Arctic Fox 5er came with a Suburban SF 30F furnace and when it runs, the fan is very noisy. I am contemplating insulating the unit to make it quieter. I noticed that Suburban now makes a "quiet" version of the same furnace. Anyone have any experience between noise levels of the quiet vs the normal? Or perhaps insulating the old one vs the "quiet" one?
9 REPLIES 9
RV_daytrader
SCVJeff wrote:
I have NEVER seen a sleeve bearing that once is sticky or noisy be rescued by oil. At that points its simply a bandaid
But if he oils the bearings and it gets quiet, then he knows that replacing the motor will make it quiet...a lot cheaper than buying a new furnace.
YODA...our lil Toyota!
1989 Toyota Seabreeze
SCVJeff
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
midnightsadie
so pull it out lube the fan bearings, and give it a try.
Bluebeard
The camper is new to us, so don't know history. I called Suburban, and woman wouldn't give me any idea of how quiet it is. She said they were buying motors from another newer supplier. She suggested I go to a deealership and listen to a camper that has the quiet one installed.
j-d
Always been noisy? Or has it gotten progressively noisy over time? If over time, motor bearings are a possibility. So are an obstruction in the air supply/exhaust ducting OR a nest in the blower itself.
pdogg
sometimes replacing the motor will quiet it down.. The Sleeve bearings dry out over time and start to whine.
time2roll
If the "quiet" furnace is a two speed unit you will have better results with a swap.
SCVJeff
Call them up and see if there is an upgrade kit
Jeff - WA6EQU
old_guy
what ever you do to reduce the noise, do not block the cold air intake in the trailer
