May-21-2020 06:37 PM
May-23-2020 04:55 PM
Old-Biscuit wrote:dougrainer wrote:Old-Biscuit wrote:
Dinosaur Electronics Circuit Boards are higher quality then Norcold OEM board
Dino Board is NOT your issue
Runs fine on Generator but problem on Shore Power
Shore Power Supply is your issue.......not the heater element/Dino Circuit Board
They are higher quality, but CAN Have a Failure. NOBODY makes a 100% perfect product. Doug
"YOUR problem is simple, you used a NON Norcold control board."
:h :R
May-23-2020 04:46 PM
May-23-2020 04:42 PM
May-23-2020 06:11 AM
May-22-2020 10:55 PM
May-22-2020 03:20 PM
Donebee wrote:GordonThree wrote:
So you have replaced both the heating element and the controller board?
Yes, and I just tried running the fridge on the genny, unhooked from shore power and it seemed to run without errors. I ran it for about ten minutes without error, when on shore power it was failing within 2-3 minutes.
May-22-2020 02:08 PM
May-22-2020 10:49 AM
May-22-2020 09:40 AM
May-21-2020 08:41 PM
May-21-2020 07:56 PM
