O ring measure
tarnold
In measuring for a new Oring, do you measure from the inside, outside or middle? I'm looking at my water filter and need a new ring. The ring is about 4" but 1/8" thick. So that would be about .25 difference between inside and outside. I know smaller would stretch but just wondering.
10 REPLIES 10
randallb
Go on to the website of any online water filter store. They all sell o-rings. Most of the time, when you order a single o-ring by size you get a bag of assorted o-rings. In the bag will be an o-ring that will fit your water filter. It is just as cheap to buy the o-ring "kits" as it is to buy a single o-ring and then you can give the rest of the bag to someone who uses a different brand filter than you. I currently have 5 or 6 unopened bags of o-rings in my garage. This way I have o-rings for my well filters and my trailer filters.
Randy
Ron3rd
WyoTraveler wrote:
If you look on the internet you will see they list all 3 dimensions. I.D., O.D.& dia of the material i.e. O.D minus I.D.
X2, and McMaster Carr has all this info. Measure the old one with calipers.
Equilizer Hitch
Honda EU2000
CT_WANDERER
all the work, but you need a good measurement of the thickness. And a good supplier.
WyoTraveler
gbopp
midnightsadie wrote:
X2 to the store lowes or ace .
Real hardware stores are not as common as the Big Box Stores and Chain Stores.
Fortunately they usually have what you need.
midnightsadie
beemerphile1
1. The size of a used o-ring will be different than a new one.
2. I just take the assembly to the store and test fit.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
downtheroad
I have always just taken in my old o-ring to Home Depot and found a perfect match...
But, these guys have every 0-ring under the sun listed by filter name and manufacturer....
O-Rings>>>HERE
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
fj12ryder
Smaller may stretch, but then it might be too thin to seal properly. The O-ring should have its size listed: OD, ID, and/or thickness. IOW you might find ID and thickness, or OD and thickness.
Howard and Peggy
"Don't Panic"
Chris_Bryant
The size is usually the inside diameter.
-- Chris Bryant
