โAug-09-2023 10:13 AM
โAug-16-2023 11:38 AM
laknox wrote:Krusty wrote:
I have been having the same issue with my fridge of the same vintage. I took the fridge out and set it on the ground and flipped it over several times and gave it a good shake on each side and while upside down. I put it back in and it is cooling again. I had to do this once in the past for the same issue and it had worked good up until recently. And that was in 2006. Didn't cost anything and the fridge is pretty easy to get out. May work in your situation too
Hmmm... I'll mention that. I totally spaced out that I did that in my old Komfort! The classic "burping" the fridge. ๐
Did you turn it upside down and back upright multiple times?
Lyle
โAug-15-2023 09:45 AM
pianotuna wrote:
BobsyourUncle also had success with shaking the fridge by "rolling bumping". Worth a try.
โAug-15-2023 04:30 AM
โAug-14-2023 12:35 PM
โAug-14-2023 11:26 AM
โAug-14-2023 10:56 AM
โAug-11-2023 09:06 AM
craig7h wrote:
A couple years back the Norcold in my 97 coach decided it was time to stop working. Of course we were in the middle of a monthlong trip.
Anyway after going back and forth about a new frig. or replace the cooling unit. I decided to replace the cooling unit as a DIY project.
I decided that way for a couple reasons, one I am not a very good carpenter and the replacement frig. would not look like it belonged. Get the new frig. in my unit would not be an easy task
I ended up going with replacing the cooling unit from JC Refrigeration
https://jc-refrigeration.com/
As I am always plugged in and never boondock I decided to go with the 120v only unit. It was a very easy DIY project for the DW and I. JC Refrigeration is really a customer service business. From the how to instructions to answering questions they are number one.
It took in total maybe 2 hours +/- to finish. Once in the unit has kept ice cream frozen and the adult beverage cold all on setting 5
Good Luck
โAug-11-2023 09:03 AM
Gjac wrote:
Also, I see you live in Az. and the temps have been very hot there lately. My Norcold will get up to 50 in 90 degree weather but cool into the 40's overnight when the temps drop into the 70's. How long did you keep the refer plugged in? Do you have any food inside it or is it empty? In 100 degree weather any Absorbtion refer is going to struggle in those temps. Just opening the door to check it will let warm air in especially if there is no food in there to keep things cool. Before you spend money on a new one I would keep it plugged in for several days and if the fridge is empty put a thermometer in a glass of water and check the temps that way.
โAug-11-2023 01:43 AM
โAug-10-2023 08:50 PM
laknox wrote:
The fridge in daughter and son-in-law's '98 Nash TT is on the fritz after working well just a couple months ago. Freezer is 4 degrees, but the fridge is in the 50's on both AC and gas. No ice buildup between top and bottom to impede airflow. We pulled the vent cap off and the coils look reasonably clean. Plenty of hot air up through the vent, though we didn't check the flue itself. We pulled the box around the burner and cleaned out some dirt and junk from there, but it wasn't affecting the flame. We used some canned air to blow off what we could around the burner.
All that said, should he bite the bullet and put in a new fridge or would one of the "Amish" replacement cooling units be a better choice. Almost double the cost for a new fridge. Are newer units better? How hard is it to swap out the cooling unit as a DIY project?
Thanks,
Lyle
โAug-10-2023 07:50 PM
โAug-10-2023 06:52 PM
โAug-10-2023 03:15 PM
pianotuna wrote:
I'd go 12 volt electric.
Next choice new cooling unit from the so called Amish. It can be diy
โAug-10-2023 05:52 AM
