โJan-20-2021 06:44 PM
โMay-07-2024 11:20 AM
got the same problem. Cant side intake off. not enough room. Hope somebody got idea.
โMay-07-2024 11:14 AM
I have the same problem . Bolt snapped off in intake. Cant get intake off because even if you get the inside bolt off you would loose it and the intake would not side off anyway . hopping somebody can help.
โJan-23-2021 08:24 AM
โJan-23-2021 07:48 AM
โJan-23-2021 07:38 AM
โJan-22-2021 08:01 AM
BeeeGeee wrote:
The broken piece of bolt is in the threads by the paper towel is stuffed in the intake manifold. I was able to remove some of the air cleaner housing and have better access to the busted bolt. I may be able to Dremel a hole in the bolt enough to get a bolt extractor on it and see if itโll unscrew out.
Thanks for everyoneโs input, itโs appreciated!
โJan-22-2021 06:11 AM
โJan-21-2021 05:34 PM
โJan-21-2021 12:07 PM
ksg5000 wrote:
If it were me I would drop by a small engine repair shop and get their .02.
โJan-21-2021 11:28 AM
โJan-21-2021 09:29 AM
โJan-20-2021 06:56 PM
