Onan 5500 Generator stops
Jack_Kay
We have a Onan 5500 generator in our rig that doesn't want to run more than about 10 minutes when we are driving. When parked, it runs until I shut it off. The unit only has about 28 hours which is not a lot, so the first owners didn't run it much. I changed the oil and filter the other day & thought that might help. I am able to restart after a few minutes, but it will still shut down when rolling down the road. I do have a full fuel tank & the altitude adjustment is set for sea level where we are now. I have the manual and I need to verify what code is blinking, but I don't understand what would be different about driving and sitting still. Fluids being tossed around? Any thoughts?
Jack & Kay
2015 Allegro 32CA
2014 Honda CR-V
FMCA #F341229
13 REPLIES 13
TEXAS
Before you go to a shop. Check your oil again. If you can't smell the gas put a small amount in a container. Try lighting it with a match. If it lights. You need to change the spark plugs and oil and filter.
haddy1
This is a long shot but it happened to me about 20 years ago. My generator (Onan 4KW) would run fine when stationary but shut down while moving (much like the OP). I found that a nut had come off one of the terminals and would short out intermittently causing the generator to shut down.
2019 Tiffin Phaeton 37BH
2018 Grand Cherokee Toad
Jack_Kay
TEXAS wrote:
Did the oil smell like gas. If the oil level was ok. After you added oil and now runs over. You are getting gas in the oil.Most likely running on one cylinder.
I don't think it did. I'm now thinking I need to find an Onan shop or whatever to take a look at it.
Jack & Kay
2015 Allegro 32CA
2014 Honda CR-V
FMCA #F341229
Jack_Kay
jsimons3 wrote:
Take a close look at your air filter.....it might have collapsed or
needs changing... my Onan was doing the same and mine was the filter
that was coming apart.
Filter looked good, I checked it.
Jack & Kay
2015 Allegro 32CA
2014 Honda CR-V
FMCA #F341229
jsimons3
jsmns8
TEXAS
Jack_Kay
It's an Onan Marques, (sp) 5500. Don't know what the serial number is. Well I managed to add oil, but it shut down several times, while driving with error code 36. When I got home and took the oil fill cap off, oil ran out. I decided I must have over filled it. I drained about a pint out and will try it again tomorrow.
Jack & Kay
2015 Allegro 32CA
2014 Honda CR-V
FMCA #F341229
TEXAS
Again need to know what you have. Full model and serial number.You could have a low oil level switch. Which is bouncing around when driving. Giving you a false shutdown,or you could have a pressure switch. When you are parked it takes away the stress and vibration of the road.
Jack_Kay
I just don't understand why it will run ok sitting still, if that's the case.
Jack & Kay
2015 Allegro 32CA
2014 Honda CR-V
FMCA #F341229
WyoTraveler
Jack&Kay wrote:
The code is 36 which seems unspecified stopping. Not much help. I parked too close to the pedistal to open the door to check the oil. Have to wait until I move now.
I'm betting your oil is OK. Onan repair said you can feel the fuel pump chatter as it heats up. There have been several posts about the same problem about the 1st week of July.
Jack_Kay
Jack & Kay
2015 Allegro 32CA
2014 Honda CR-V
FMCA #F341229
WyoTraveler
My 5500 Onan was doing about same thing. Has been several posts on issue. Mine threw code 36. Fuel pump was over heating. They replaced under warranty. So far runs ok. If it happens again I am going to move the fuel pump away from the generator a few feet and bolt it to the MH frame where it will get more cooling.
Dadio24
Double check the oil level once again. They have a switch to shut down when oil is low. Turning a corner will likely cause them to shut down when low alos...
