โSep-23-2013 11:02 AM
โSep-25-2013 06:12 AM
OldF**t wrote:DavidM49 wrote:
I could hear the pump running while trying to prime the carb. It was like a hammer sound more than anything. That being said, I got nothing out of the fuel line when trying to prime the carb.
Well the next step would be pulling the hose off of the pump filter to see if fuel is available from the tank. The tank should be half full or greater as the generator fuel line pickup is not at the bottom of the tank. Also the line to the tank could be bad or have a leak which would cause the pump to suck air instead of fuel.
โSep-24-2013 09:45 AM
โSep-24-2013 07:05 AM
โSep-24-2013 06:45 AM
DavidM49 wrote:
Thanks guys for the the help. Took line off of filter before carb and hit prime and not a drop of fuel came out of the line. Now the challenge is to find the airtex brand pump versus paying premium for the Onan branded pump. Thanks again!
โSep-24-2013 06:32 AM
โSep-23-2013 05:30 PM
othertonka wrote:
First take the front cover off and find the START/STOP button, lower left corner. Note that the STOP button is also a PRIME button. Press and hold down the PRIME button and you should hear the fuel pump start to click. Let it prime until the clicking stops or at least slows down. While it is clicking locate the sound of the pump and you will find it underneath the left front corner of the gen set, clamped to a rubber fuel hose and will have a filter screwed into the pump.
Priming might also assist you in your hard starting problem.
โSep-23-2013 03:56 PM
โSep-23-2013 02:06 PM
