โJan-30-2022 09:44 AM
โFeb-01-2022 09:27 AM
โFeb-01-2022 06:31 AM
โJan-31-2022 03:51 PM
hotjag1 wrote:
Wow, I always thought I had a 6500w generator. Wolfe 10 was right. It is a 7500w gen. Model #5HDKAJ 11451H. s/n B030472922
I pushed on the top of the rocker switch which I always thought was for the glow plugs. If it is a primer switch, I didn't hear anything from the fuel pump when it was pushed. I am in 75 degree temps if that makes a difference.
The last time I got it to run, it ran for 3 minutes and 20 seconds. It is more difficult to start each time.
I have over a half tank of fuel according to the gauge which has always been accurate.
Hope I answered most questions.
โJan-31-2022 03:38 PM
โJan-31-2022 01:22 PM
โJan-31-2022 04:58 AM
โJan-31-2022 02:19 AM
โJan-30-2022 07:59 PM
hotjag1 wrote:
Thanks for the replies. I will start looking for a fuel restriction somewhere in the line tomorrow.
The code light flashes 3 times. The label beside it says "needs servicing". No kidding...lol
I will check the run time tomorrow after I get out of the dentist.
The microwave and or coffee machine work fine while the generator is running, so I don't think there is a voltage issue.
โJan-30-2022 05:53 PM
The microwave and or coffee machine work fine while the generator is running, so I don't think there is a voltage issue.These appliances may have a wide tolerance of voltage variation. What is the AC voltage? :h
โJan-30-2022 05:49 PM
โJan-30-2022 02:17 PM
gbopp wrote:Reisender wrote:
Gas or diesel?
It says Onan Diesel Generator in the title of the post.
โJan-30-2022 01:25 PM
Reisender wrote:
Gas or diesel?
โJan-30-2022 12:06 PM
โJan-30-2022 12:00 PM
hotjag1 wrote:
I browse this forum fairly often, but now I need some advice or expertise on what is wrong with my generator.
It is a 6500 watt Onan. It starts up fairly quickly and generates power within a couple of minutes of running time, but it shuts down after about 5 minutes of run time with or without any load on it. It will restart after about a minute, but runs rough as it starts and then smooths out after about 5 seconds.
It will then run for about 5 minutes before shutting down again. I suspect that it is not getting enough fuel, although it was serviced with oil change, new fuel and air filter about 6 months ago. All suggestions are welcome.
