Onan V/regulator testing
Cstoliker
Having issues with my Onan microlite 4k generator. I think the voltage regulator (model 305-0851) may be at fault. Before replacing a $200-300 dollor part can someone give me a testing procedure or literature on how to test?
Thanks
Genorater starts but stalls as soon as the start button is released. It is producing power just won't run off its own power. Possibly a relay in the regulater. But it is a sealed non serviceable part. pcb is in a box and covered with epoxy??
13 REPLIES 13
Cstoliker
Does anyone know of the pcb 305-0851 could be replaced by a 300-3056?
Cstoliker
Thanks Kpack!
Cstoliker
Well I tryed it just unplugged too same thing.
Kpackpackkelley
Some spec's had a low oil switch.
Handbasket
Ranger Smith wrote:
Generator Jim wrote:
***Oil sensor has been unplugged and grounded ***
Remove the ground, that's how the oil sensor shuts the unit down.
JimL
Is it a normally closed sensor that opens with pressure or is it a normally open sensor that closes with oil pressure. I thought it was the latter.
Micro-series are splash-lubed. No oil pump, so no oil pressure to operate a switch. If it's got a low-oil safety, it's probably a float.
Jim, "Life is short. Drink faster."
'06 Tiger CX 'C Minus' on a Silverado 2500HD 4x4, 8.1 & Allison (aka 'Loafer's Glory')
Ranger_Smith
JimL
Where we are now
Amateur Radio Operator WW1SS . . . Flex 6500 PGXL and TGXL
Steve and Joy
2014 Itasca Suncruiser 38Q . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
Generator_Jim
JimL
Jim & Jane Latour
08 Chevy 3500HD, crew cab, dually, Duramax/Allison
Crossroads Cruiser CR305SK14, Onan 3.6KY
Retired AF CMS (E9) Power Generation and Onan RV genset Level III tech
Grand Strand Sams
Blog.rv.net
Kpackpackkelley
Chris Bryant wrote:
There is an excellent guide (link to pdf file) on the Flight Systems website. They also sell the best, imho, replacements.
I believe flight systems will test old one for 25.00
Kpackpackkelley
Cstoliker
Model # 4KYFA26100B
About 2500 hours
Oil sensor has been unplugged and grounded. Remote panel disconnected. Same result. when running (with start buton pressed)it's does produce power.
On very rare occasions it will run normally, when it does it's rock solid which leads me to believe its a mechanical failure like a stuck relay.
Chris_Bryant
-- Chris Bryant
Kpackpackkelley
What is the spec letter on that 4k and I'll post a service manual.
There are a lot of of things that it could be need to test them before you buy that brain and it still does the same thing. Don't just just start throwing parts at it ..
Start by looking at all connections then the start soleniod.
When you let off the start switch it has to be making power to run.
How many hrs are on the unit ?
Ranger_Smith
I don't believe there is a way to test it. When mine went bad it was all one unit and cost was $1800 for the part for my diesel generator.
Where we are now
Steve and Joy
