โOct-08-2017 04:43 PM
โOct-10-2017 03:08 PM
โOct-10-2017 02:55 PM
barko1 wrote:You'll need a 2nd one, especially if the Westinghouse is overrated for wattage, which is common for cheaper products. If it will run (more importantly, START) your air it will be working very hard.
I figure I'd buy one that I can parallel so I can add a second if needed or desired. I don't want the weight of a 3000. Looking at a Westinghouse 2200/2500.
โOct-10-2017 02:45 PM
barko1 wrote:
Thanks for all the input. I have a 13,500 AC unit. It seems that some people can run the AC from a 2000, some can't. I figure I'd buy one that I can parallel so I can add a second if needed or desired. I don't want the weight of a 3000. Looking at a Westinghouse 2200/2500.
โOct-10-2017 02:42 PM
time2roll wrote:
Probably split phase 240v so only half power available at each 120v outlet.
I recommend a generator with a 30 amp 120v outlet for best power results.
โOct-10-2017 02:20 PM
โOct-10-2017 08:43 AM
2oldman wrote:Probably split phase 240v so only half power available at each 120v outlet.maillemaker wrote:Cheap generators have very little surge capability.
We went down to Harbor Freight and picked up a 4000W generator on sale for $287. It only had 13A / 110VAC outlets. These would not run our air conditioner - the circuit breaker kept tripping on the genset.
โOct-10-2017 07:29 AM
โOct-09-2017 08:52 AM
โOct-09-2017 08:24 AM
barko1 wrote:
New to using a generator and while shopping I did notice that some, not many, come with a 30 amp connector that my RV would connect to but most have the standard duplex receptacles. Do I just plug in the the 110 with an adaptor to run the AC? THANKS
โOct-08-2017 05:35 PM
โOct-08-2017 05:05 PM
โOct-08-2017 05:03 PM
โOct-08-2017 04:46 PM
