โMar-26-2015 01:35 PM
โMar-27-2015 12:27 PM
AllegroD wrote:smkettner wrote:
Tank has an OPD valve to prevent over fill. Tank is already designed to stop at 80%. No need to short fill to 80% of 80%.
100% filled to capacity (40 lbs.) is 80%.
Considering the age of your rig, the above should be the answer.12th Man Fan wrote:
For those of you that want me to do a search, I did and got 503 pages and although I am retired I don't have enough time to read all of the info.
So your answer to the many hundreds of RV.NET forum is that they should repost their answers and their time is not as valuable as yours.
โMar-27-2015 11:49 AM
โMar-27-2015 11:28 AM
โMar-27-2015 11:27 AM
RJsfishin wrote:RJ, I should have said that this was from an older cylinder. I frickin' didn't dream it! Near death experiences leave me with valuable lessons learned.
Quote:
I would be more concerned about the safety release that is built into every cylinder. At a certain pressure, the safety release opens and a large volume of both gas and liquid is expelled. It happened to me, once. The cloud emitted is so dense that you can't see your outstretched hand.
This is not true at all !
Did you dream this ?? If this really happened, you had better get it fixed quick, because this could make for a very dangerous situation.
In reality, a LP safety release valve releases the LP gas no faster than the gas is expanding and needs to release, which is seldom more than a hissing sound that can be heard and smelled when close by. It presents absolutely no hazard as long as there is no open flame w/in 50 feet.
It is not a pop off valve, such as found on an oxygen bottle, that really will expel its entire volume if it gets over pressured.
It is a bleeder valve, and will NEVER bleed off more than needed for expansion.
โMar-27-2015 10:57 AM
โMar-27-2015 10:48 AM
โMar-27-2015 10:45 AM
โMar-27-2015 10:32 AM
โMar-27-2015 10:23 AM
BillyW wrote:
Who's on first?
โMar-27-2015 09:17 AM
โMar-27-2015 08:42 AM
โMar-27-2015 08:20 AM
โMar-27-2015 08:10 AM
smkettner wrote:mmiille wrote:
So the lp gas weighs 4.11 pounds per gallon. A 40 pound tank at 80% would hold 32 gallons. That would be 131 pounds. A 20 pound tank at 80% would be 65 pounds.
40 / 4.11 = 9.73 gallons. Check the fuel gauge on the pump next time you fill.
A 40 lb tank holds 40 lbs of propane, no calculation needed.
And yes the 9.73 gallons (40lbs) is considered 100% filled even though there remains 20% of space in the tank for expansion.
โMar-27-2015 07:59 AM
โMar-27-2015 07:24 AM
sato4000 wrote:
My RV dealer said he will fill up the propane 100 percent if you want.
