โMar-17-2018 05:22 PM
โMar-18-2018 12:37 PM
vtchris wrote:
Dometic fridge 2410. On propane it runs fine for about 12-24 hours and then just turns itself off. I hit the pezel (spelling) and it lights right up and works fine again. It has been happening these past 3-4 days. The flame is nice and blue and strong. Tapping the chimney gently and nothing falls down. Any ideas? The fridge is about 7 years old. TIA.
โMar-18-2018 12:34 PM
Old-Biscuit wrote:vtchris wrote:
Yes, piezo ignition. There is no control board, this is an old fashion type gas/electric fridge. And I don't know how to take the burner apart and clean it. Can someone explain?
Service Manual that covers your model
Problem with flame going out could be 'bypass' setting/propane pressure and or 'flue cap' out of position. More then likely issue with 'bypass'
โMar-18-2018 10:53 AM
โMar-18-2018 10:32 AM
ppine wrote:
Dirt is the enemy of trailer appliances. Clean everything and they work fine. I have an older trailer with a great refer, but once in awhile it would go out. I had a mobile RV repair guy working on something else and mentioned the refer. He took the burner apart and cleaned it in about 2 minutes. Works like new.
RVs are not like houses. Sometimes when I get frustrated with the appliances I call a guy. Maybe it costs $50 or a little more. Then everything works and life is good. Well worth it.
โMar-18-2018 10:04 AM
โMar-18-2018 07:17 AM
โMar-18-2018 12:17 AM
โMar-17-2018 10:51 PM
โMar-17-2018 07:23 PM
โMar-17-2018 05:38 PM
