Propane Leak
Ojibwa53
Filled left side propane before camping this past weekend, get to resort and smell gas . (Right tank half full) . Checked bottles with soapy water mix (no bubbles) Two stage reglator (main) with single reglator on left. turn offed newly fulled bottle didn't smell gas anymore (purge screw tight). Could the reglator be bad? (2011 5th wheel).
7 REPLIES 7
Ojibwa53
Changed the single stage regulator, problem solved . Thanks for the replys .
Ojibwa53
Thanks for the info, didn't check the single stage regulator, will check tomorrow .
doughere
I've had a tank that would not connect properly sometimes, had to replace.
Helped a friend with his leak, was leaking from the vent on the regulator, replaced.
Doug
doughere
oops
newman_fulltime
make sure the hose ison the bottle properly and tight
RJsfishin
Doubtful a real leak fixes itself, so do you suppose it got a touch overfilled and bleeding a little off ? I know, its very hard to even get one full these days, let alone overfilled.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
Old-Biscuit
Did you spray the RED regulator..the hose/fittings on the left side cylinder?
That RED regulator is a 30# single stage regulator. Drops cylinder pressure down to 30# and then it goes across to other side and main 2 stage regulator.
The hose that goes across....check it for leaks also
