Home Depot Roof Junction Box for Panels
RJsfishin
Anyone have a pic or description of the HD roof junction box that was said to work good for solar panel connecting ?
I was in HD, and nearly went crazy looking at all the boxes,.....that mite or mite not work. None really impressed me at first glance.
Thanks for any info.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
17 REPLIES 17
TechWriter
crcr wrote:
TechWriter wrote:
brulaz wrote:
The grey plastic junction box I used was 4x4x2" with no holes in it. The top was sealed with 4 screws and a rubber gasket. It had 4 tabs along the outside to screw it to the roof.
I tried these and the sun will do a job on them -- especially watch for the cover to warp.
So what box of what material do you use?
I use these:
These are virtually flat so I install them under a panel -- no sun hits it.
www.rvSeniorMoments.com
DISH TV for RVs
brulaz
mchero wrote:
What do you all use to keep the wires from the combiner box to the panels secure?
A dab of caulk every couple of feet. I was using 3M 4200.
2014 ORV Timber Ridge 240RKS,8500#,1250# tongue,44K miles
690W Rooftop + 340W Portable Solar,4 GC2s,215Ah@24V
2016 Ram 2500 4x4 RgCab CTD,2507# payload,10.8 mpgUS tow
mchero
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar dieselrvowners.com
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
Fubeca
Mine looks very much like the one pictured near the bottom of this page:
http://handybobsolar.wordpress.com/april-2012-the-money-question/
I see no reason for strain relief on my box I'll just be using Dicor or another sealant as shown.
I will be painting the box white to attempt to delay the sun damage.
brulaz
mchero wrote:
What's the cost of this box? I assume the strain relief's are separate purchase as well?
Maybe $5-$10 ??
And yes, the strain relief's were a separate purchase (all at Home Depot) and I had to drill the two holes in the side of the box to mount them.
brulaz
Since that photo I've sealed the cover joints and screws with more 3M 4200.
But you're right about the sun. I've got some white fibreglass deck paint and will paint all the remaining grey bits with that. Hopefully that'll be enough UV protection.
2oldman
crcr
TechWriter
DISH TV for RVs
RJsfishin
Mine is the same, cept its round, and a "pot metal" material, and I had choice of white I think I'll grind the 2 mounting ears off the outside, and screw it down from the inside w/ Dycor under it..
Rich
mchero
I was looking at some boxes on the solar sites like this one;
http://www.altestore.com/store/Enclosures-Electrical-Safety/Electrical-Enclosures/Combiner-Pass-Thro...
Robert McHenry
3_tons
I've used one and it works perfectly.
brulaz
I cut a hole in the roof and in the bottom of the box to match and used lots of 3M 4200 and SS screws to attach it.
The wires enter the box through two strain relief fittings, compression type with rubber O-rings. I think they were for cable TV wiring. The solar panel wires fit perfectly.
RJsfishin
Thanks, I found one, looks perdy good.
Rich
