Aug-28-2023 01:12 AM
Aug-31-2023 10:09 AM
Aug-30-2023 06:02 PM
RLS7201 wrote:wa8yxm wrote:
The key word "MOUNTED" means that it should not NEED recertification.
Only luggable tanks need that.
You are absolutely correct for USA standards.
You are absolutely incorrect for Canadian standards.
I can not fill my 28 year old ASME tank in Canada.
Richard
Aug-30-2023 04:26 PM
Aug-30-2023 03:54 PM
Aug-30-2023 08:58 AM
Aug-30-2023 04:41 AM
mcewena wrote:dougrainer wrote:
USA ASME tanks are not required for certification. Are you POSITIVE, that Canada requires ASME certification and not just DOT portable tanks which DO require recertification? Doug
I’m positive that some fill stations won’t fill my tank. That’s what matters in the long run.
Canadian regulations are hard to pin down but I talked to a local propane recertifier and he said he probably wouldn’t pass mine due to the rust so I know I’m on borrowed time with it.
Aug-30-2023 12:34 AM
Grit dog wrote:
I’d run er til she pukes.
You don’t appear to know definitively if it’s rusted enough to be compromised soon. That’s step 1.
If it’s not like half rusted through, give it a Rustoleum rebuild and find a place that isn’t so nosy to get it filled.
JMO
Aug-29-2023 07:51 AM
Aug-29-2023 07:39 AM
Clean it up and paint it, they do not want to see rust. ASME tanks do not need to be certified in Canada. My motorhome 1986, tank is clean and painted.
Aug-29-2023 07:29 AM
Aug-29-2023 05:40 AM
Aug-29-2023 12:27 AM
Ava wrote:
My 94 DP Bounder still has the original tank. I have never had any problem filling it here in Canada or the US
Aug-28-2023 09:44 PM
Aug-28-2023 03:37 PM
mcewena wrote:Dutch_12078 wrote:
A rack fabricated to hold two or three 20 lb BBQ cylinders upright could work using an automatic switchover regulator setup.
Can they be used/stored/transported on their side or 45 degrees?
