โFeb-08-2020 03:39 PM
โFeb-09-2020 02:00 PM
wopachop wrote:
I was cycling my onan5500 a couple days ago. Store my batteries in the garage.
Pulled out battery to start the genny. Ran for about 55mins. Genny still running I disconnected the negative cable and it died instantly.
Also had my 12v disconnect switch turned off.
Made me wonder the dealio. If the disconnect switch was turned on, would the converter then power the fuel pump?
Will have to test that next month. The fuel bowl was filled with gas so I guess it wasnt a fuel pump issue but instead a "making spark" issue?
โFeb-09-2020 12:27 PM
โFeb-09-2020 11:13 AM
โFeb-09-2020 09:25 AM
โFeb-09-2020 09:20 AM
Son of Norway wrote:
Something I have never understood about generators (I have an Onan 6.5 Emerald III.) A 12-volt DC battery is used to start the generator, which then produces 120V AC. The battery supplies the energy needed to run the generator, right? So, while the generator is running, does it send a 12-volt DC current back to the battery to keep it charged, or does the generator just continue to drain the battery until the battery no longer has enough voltage to keep it running?
So if the generator drains the battery, then there must be a converter in the circuit to keep the battery charged, just like the alternator on a car engine. OK, I'm no electrical engineer, I just want to be sure that I understand this correctly.
Thanks for your tolerance on this post.
โFeb-09-2020 09:01 AM
โFeb-09-2020 08:42 AM
โFeb-09-2020 07:37 AM
โFeb-09-2020 03:13 AM
โFeb-08-2020 04:19 PM
Bud
USAF Retired
Pace Arrow
โFeb-08-2020 04:17 PM
