Mar-26-2016 09:02 PM
Mar-28-2016 10:12 AM
otrfun wrote:
Have plans to pickup our new toy hauler (with 50 amp capability) next week.
Couple Questions:
1. When you use a 30 amp to 50 amp pigtail converter plug, is the single 30 amp input simply placed in parallel with each/both of the TT's two 50 amp circuits?
2. For those that use a 50 amp Progressive Industries EMS system with their on-board OEM 4000/5500 Onan generator, do you have any issues with the E4 ground error? I ask because I've found a bonding plug is necessary when using the 30 amp PI EMS with a portable Honda/Yamaha/Champion generator.
Thanks!
Mar-28-2016 07:38 AM
CA Traveler wrote:
1. It protects the ATS
2. My gen will never have a failue! :B
Mar-27-2016 02:02 PM
otrfun wrote:99% of RVers are clueless about WFCO chargers and they are cheap - As the salesman say you have this nice 50A battery charger...:S Make sure both chargers are compatible but regardless the WFCO probably won't contribute much charging.
Thanks for all the helpful replies. The 50 amp service on our new toy hauler is a bit new to me.
Trying to get ahead of everything before I pick it up Wed. I have plans to install a 50 amp EMS and a 2nd converter, a PD 9260, which I'll be paralleling with the OEM WFCO converter.
Hard to believe the OEM's continue to install these WFCO's 😞
Mar-27-2016 08:49 AM
Mar-27-2016 08:14 AM
Mar-27-2016 05:54 AM
Mar-26-2016 11:03 PM
Mar-26-2016 10:53 PM
