Quick Vote: Battery Reservoir Cover Caps -- On or Off?
CopilotCompanio
Placed my 12 volt battery on a trickle charger in the garage today. Friend insisted the caps that cover the water reserviors should be opened to avoid a build up of gases that would lead to an explosion. That sounds like a good way for the water to evaporate to me but I didn't want to contradict him. (He'd been kind enough to help me lift a battery that was too heavy for me.). And, to tell you the truth, I wasn't really sure?
I'll watch the battery over the Winter. But should I re-cover the water reservoir with the caps? What say you? Caps on? Or caps off?
Thanks, in advance,
/CC
DH: Designated Curmudgeon
Lupé the Rescue Dog: Self-appointed Tattletale
DW: Copilot & Companion
No offense intended. Sarcasm is my strong suit.
23 REPLIES 23
CharlesinGA
That is about the *%#*@! suggestion I have ever heard (not condemning you, you asked a legitimate question, I am commenting on your friend)
Automobile alternators put out from 60 to 180 amp, and charge the batteries fairly heavy after a normal start. Does your friend remove the caps on his car batteries when he is driving? Or a golf cart when it is charging, or a electric man lift when it is plugged in, or anything else with batteries with removable caps?
The caps are vented.
Charles
'03 Ram 2500 CTD, 5.9HO six speed, PacBrake Exh Brake, std cab, long bed, Leer top and 2008 Bigfoot 25B21RB.. previously (both gone) 2008 Thor/Dutchman Freedom Spirit 180 & 2007 Winnebago View 23H Motorhome.
pianotuna
Nomad III
Nomad III
Remove them to equalize charge the battery. For normal charging leave them in place.
Regards, Don
MrWizard
Moderator
Moderator
leave them in place
many years ago maybe 50?
when batteries were shipped dry/empty
it was common to add the acid, then hit them with a high voltage charge
and the caps were left off for this initial activation
but normal charging, normal floating/tending does NOT need them to be remove
I can explain it to you.
1997 F53 Bounder 36s
red31
ScottG
Agree with others; they're vented and designed to be left in place when charging.
Does your buddy take his off when he's driving his car? 😉
gypsmjim
I would NEVER use a trickle charger, but that's another story. In the old days I would always take the caps of when on the charger, and then put them back on when it was fully charged. Charge them up and then let them sit another month off season before charging again.
Recently I had a problem with a battery that was still under warranty. The dealer said NO NO NO don't take the caps off when charging. Just for laughs I asked several other dealers. They all said the same thing.
Now if you insist on trickling, and thus keeping the acid boiling all the time, then maybe you should check weekly for fluid loss, whether you use the caps or not.
2015 Jayco Flight SLX 195RB
Permanently set up on a beautiful mountaintop retreat in Southwest NYS
gbopp
When the batteries are in service they charge with the caps on.
Leave the caps installed. And, use a battey tender, not a trickle charger.
Trackrig
Leave them on, they're vented.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
w4phj
Leave caps installed.
2021 Winnebago View 24J
2021 Ram pick up
2015 Jeep Wrangler Unlimited Sahara
Ham Radio Extra Class Volunteer Examiner
FAA A&P License
1969 Plymouth Road Runner
