Recently turned on the coach and noticed the video feed to the rear showed a picture then some "static". The picture went blank and now only shows several white parallel lines. Double lines when camera is connected. Single white line on Cam2 with no camera connected.
The Voyager monitor was replaced about 5 years ago due to a monitor failure. This does not appear to be the same issue. Unit is b/w.
Camera model is VBCS150.
Coach is identified in sig.
On edit:
Disconnected camera and reconnected. Moved cable to Cam2. Still no pic. Now appears to be another VOM 58 monitor failure.
'04 Cross Country 35' w/300 Cummins
'14 Ford Escape on KarKaddy 460SS
'09 Dodge Ram 1500 4x4 Crew 5.7 Hemi MDS
'51 & '53 Hudson Hornets 308 6cyl w/
TWIN H-POWER
5 lbs of BG the YorkieMembers of:
Grand Canyon Chapter of Hudson Essex Terraplane Club Inc
