Bypass valve on heater leaks back
Thunder_Mountai
As subject says, the brass bypass valve on the back of the Atwood allows the pink stuff to leak back into the water heater. My question for you folks is can the valve be fixed by replacing an internal washer like a hose bib or old style faucet?
2016 Winnebago Journey 40R
2018 Rubicon
1982 FJ40 Toyota Land Cruiser
2020 Keystone Outback 327CG
2020 Dodge Ram 2500
Polaris RZR XP 1000
4 Cats
3 Dogs
1 Bottle of Jack Daniels
Two old hippies still trying to find ourselves!
8 REPLIES 8
Thunder_Mountai
Thanks for the replies. Posting pictures is such a pain on this forum. Not sure I could get a camera or phone into the space. I actually have a brass valve with a handle. It is not a check valve. All the pipe connecting the valve to the heater is metal pipe.
2018 Rubicon
2020 Dodge Ram 2500
Polaris RZR XP 1000
4 Cats
3 Dogs
RLS7201
duplicate
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
RLS7201
Look more closely. There is a check valve between the ball valve and the tank. The check valve has failed.
Richard
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
Old-Biscuit
Typical 'check valves' used in RV plumbing whether they have a plastic body or a brass body are nothing more than a plunger/spring/o-ring assembly.
O-ring on end of plunger.....spring held in place with a clip.
Spring holds plunger closed and o-ring seals.
Water pressure pushes plunger OPEN.
O-ring can get shifted out of grove
O-ring can be torn/deteriorated
Plunger can get cockeyed
I hate them because they are plastic junk
Remove them.......install a shut off valve (Sharkbite) and be done with problems.
OR get a true check valve (brass swing check) at Home Depot and replace the junk on with an all metal one
1/2" swing check valve........need short nipples to install
calamus
can you post a link to a picture? If nothing else You could just replumb the whole thing Menards/ home depot have 1/2" pex 1/4 turn ball ball valves and rings and short lengths of pipe you can get the tool and and supplies for $60 and have a $40 tool to have in emergency. I have carried mine for years and saved quite a few peoples weekends.
2015 3500HD Chevy Dually Duramax, 2008 Sundance 2014 22'SSX bennington pontoon
Thunder_Mountai
powderman426 wrote:
Mine had the check valve that leaked also. I replaced it with a manual valve. Problem solved.
Mine is a brass gate valve that is more or less hard plumbed onto the back of the hot water heater. Doesn't look like it is an easy removal.
2018 Rubicon
2020 Dodge Ram 2500
Polaris RZR XP 1000
4 Cats
3 Dogs
powderman426
Ron & Charlotte
WD8CBT since 1976
32' Gulfstream Ameri-Camp & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
calamus
Not sure about yours but ours is a 1/4 turn ball valve. just cut it out and replace it with a new one 1/2" pex
