โNov-16-2016 04:02 PM
โNov-17-2016 08:13 AM
โNov-17-2016 08:03 AM
โNov-17-2016 07:59 AM
โNov-17-2016 07:05 AM
โNov-17-2016 04:45 AM
MEXICOWANDERER wrote:Typically what size wiring does a stock Ford or Chevy alternator come with? In gross terms if your batteries are at 50 percent SOC with stock wiring how many amps can you pump into 2 GC batteries? With 4 gage wiring how many amps will you see?
His alternator has a lot of lead in it's pencil and nobody to write to. Am I getting this across...Vehicle wiring harnesses to the chassis battery restrict amperage horribly. The 4 gauge new wire must be dedicated RIGHT FROM THE OUTPUT STUD OF THE ALTERNATOR DIRECT TO BATTERY POSITIVE VIA A CHARGE DIVIDER AND CIRCUIT BREAKER. I don't read this stuff out of a book or put on a propeller beanie and play the part of Gyro Gearloose...I did it and do it for a living. As an engineer not a shoe salesman. Maybe I'm wasting my breath here.
โNov-17-2016 04:10 AM
โNov-17-2016 03:52 AM
MrWizard wrote:TheOldWizard1 wrote:
I am quite surprised you got that much charging done from your TV !
TV charging systems are optimized to charge ONE non-deep discharge battery. There are many assumptions made by the charging system about the this type of battery and its location.
NOT a truck and trailer
he has a Class C RV, also NOT the cheapest one,
his complete battery and charging system except maybe the alternator
has seen serious upgrades in wiring and capacity
โNov-17-2016 03:06 AM
โNov-16-2016 10:37 PM
โNov-16-2016 09:22 PM
โNov-16-2016 08:52 PM
pianotuna wrote:
The first two hours, very little in the way of charging happened as I was using the head lights, running the heater fan on high and running the laptop with Microsoft Streets and trips. In fact, at first I was concerned that the alternator was not sending any energy to the house bank.
I stopped about 5 p.m. in Fargo, ND and voltage was back up to 12.9 (under load from the fridge and attempting to recharge a tablet, using a 12 volt adapter.)
โNov-16-2016 08:40 PM
โNov-16-2016 08:05 PM
โNov-16-2016 07:48 PM
โNov-16-2016 06:41 PM
